Hey all,
What are your thoughts on using a Linux distro for Autodesk Maya primarily for rendering?
I'd need to have Photoshop on Linux too, which I believe can be achived via Wine?
Anyway, does anyone have any experience with this?
How well does it run?
Which distro should I use? Primarily for Maya/PS/web browsing.
The only reason I'm wanting to try this is I heard that it is considerably quicker due to the OS not using as many resources... I don't know how true this is, but hey, it's worth a shot!
I have never use any Linux distro (well, minus Android and Meego on my phones)... Anyway, what are your thoughts on this?
I think it's a route worth exploring. After all, going with Linux saves you a few bucks. Photoshop can work, but there might some minor issues:
http://appdb.winehq.org/objectManager.php?sClass=version&iId=25607
You could always try GIMP as well, which works natively on linux.
As for a distro recommendation, I'd opt for Linux Mint.
Thanks, man.
I'll look into it.
I've used The GIMP on Win7... Yeah.... I just can't do it. It has a horrible UI IMO.
Why Linux Mint? What does it offer that others don't? Why do you think it would be best suited for Maya?
I ask because I really know nothing about it any of the distros and how they differ.
Cheers,
-Tragedy-
Well, keep in mind GIMP (GNU Image Manipulation Program) was made for Linux - it's a port to Windows. You can change the UI a bit; I believe there are a few different layouts.
https://www.youtube.com/watch?v=BSUP1WhSaSw
I like Mint becuase it's easy to set up (not too hellbent on FOSS only - comes with codecs and flash out of the box), and has a traditional desktop set up. It also has a Ubuntu base, you get good software support, and a lot of the technical support is interchangable with Ubuntu. It's great for newbies, or for just lazy people. I use Linux Mint on all my machines. If you need stability, go for Linux Mint 13. It's an LTS release based on Ubuntu 12.04. Will be supported until April 2017.
