Linux for a beginner
im not that big on knowing os's but what is the most user friendly linux distro?
if all you value is user friendliness and simplicity I say just pick a debian varient
Grab a few to try & run it off a 'live' usb until you find one you like - openSUSE, Mint (my personal favourite & even my mum can use it its that simple), Ubuntu, arch... there is just so many that are really easy to use out of the box so to speak.
Once you find the one you like, youtube about how to navigate and use it. Maybe even buy a book on how to play around with the console commands once you get familiar with the interface etc.
Zorin.
Personally I think Monjaro or Arch are the 2 easiest Linuxes to get into, they are extremely user friendly and supported by the community. And unlike some other distros, they are pretty easy to use as well where if you don't want to, you don't have to go into the Terminal to get drivers and programs, etc.
Are you sure you know what you're talking about? Arch doesn't even have a graphical installer, let alone a graphical package manager, on the official iso. Manjaro, on the other hand, does, but it is Arch-based, not a base Arch system.
Manjaro and Sabayon, they are based off more advanced distros(arch for Manjaro and Gentoo for Sbayon). They are easy to use and work out of the box. They also have all the features of their parent distros. So, you can learn via a top down approach. Install and then slowly delve deeper into setting and features.
Fedora (Made by Redhat) and Opensuse (Made by Novell) are worthwhile as well. Both of those are used as the test bed for the enterprise version of distro. So if you are interested learning Linux for business reasons they are also a good place to start.
Finally you could just use Arch or Gentoo and learn the bottom up way. Build your own system from the ground up. I don't recommend this way unless you are very patient and have an extra computer in case you mess up.
Arch is not user friendly but maybe the best distro to learn linux (along with gentoo), if you want a graphical installer for arch try antegros.
Try mint maybe, but keep in mind you have to reinstall on each new release.. Ubuntu is also user friendly but not rolling release, which you might want if you want the newest software at all time. Suse Linux is very nice IMHO as it provides GUI tools to manage the entire system, it's also not a rolling release.. A friendly rolling release distro might be Sabayon as suggested, or Manjaro, I tend to avoid both because of compatibilty issues I've had as Sabayon (at least back when I tried it) is based on Gentoo but adds more repositories, which used to break updates for me. Manjaro does the same with Arch, when trying it it was fairly stable, however it didn't like to play well with my hybrid graphics card so I went back to Arch.. If you just care about the installer, and then don't mind installing your own tools or doing your configurations through text files, give Antegros a try, it basically installs arch with a graphical user interface. If you feel like learning linux go with Arch or Gentoo installation using their guides..
NONE. Linux is terribly confusing. It looks simple on the surface, but guaranteed, you will run into an error. You will go to the forum and they'll kinda, solve your problem (maybe). Then after which stuff will fall apart...the "help" everyone talks about will turn into a squabbling of conflicting opinions, the choice now become a confusing maze of options that are really pretty much the same.
Anyway, sry for the rant. I didn't have the best linux experience. If you really want a good distro, I would look at with Desktop Environment (user interface) you like, and get an ubuntu-based distro with it preinstalle
I say this because ease of use depends on you, linux looks like the way you want it to, and the User Interface is the most important part
Good ones include:
LXDE (Lubuntu)
XFCE (Xubuntu)
KDE (Kubuntu)
Unity (Ubuntu)
Gnome (ubuntu-Gnome 'Gubuntu')
You think you can throw Arch at a beginner?
OpenSUSE or Sabayon, nuff said :P
No really both distros are superb, openSUSE I would say is more user friendly but both are pretty much, I prefer the RPM package manager over any, but do try each distro and see what you think, its not going to cost you anything but time.
Also Cyberdork34 what distro did you use? OpenSUSE is superb for stability, I have had issues with Ubuntu and GPU drivers to the point I couldnt even get into the terminal, this also happened on the spins of Ubuntu.
arch isn't that hard. i'm new to linux and i read a lot and you just need to follow the wiki or ask awesome people on this forum like i did:)
used the ubuntu family (ubuntu and kubuntu). 12.04 was amazing, but anything higher was an unstable mess
My kids (5 and 7 years old) have Mint 13 on their computer. I'm pretty sure if children can use it, it fits the definition of "for a beginner". There's also the fact that it will be supported for 3 more years, and they recently backported quite a bit of the software of newer Mint versions to it. Since it is an Ubuntu derivative, it is compatible with all Ubuntu software (it is essentially Ubuntu 12.04).
I prefer the Cinnamon edition, but the mate environment is good too. KDE is extremely customizable, but can be a resource hog.
