- I decided to install Linux on my laptop. The first problem I have encountered is adding my Linux OS to my Windows Domain, I have everything setup on the server end possibly on my laptop. Here is what I am using right now, i am currently using a Dell Latitude D530 with Zorin OS 7, which is a ubuntu based Linux Operating System
- The error log I saved:
'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_anchors = DIR:/var/lib/likewise/trusted_certs
20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_cert_match = &&<EKU>msScLogin<PRINCIPAL>
20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_eku_checking = kpServerAuth
20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_win2k_require_binding = false
20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_identities = PKCS11:/usr/lib/likewise-open/libpkcs11.so
20140111042100:VERBOSE:Found krb5 name value pair ' default_keytab_name = /etc/krb5.keytab
20140111042100:VERBOSE:Found krb5 stanza '[domain_realm]
20140111042100:VERBOSE:Found krb5 name value pair ' .dmott-latitude-d530 = DMOTT-LATITUDE-D530
20140111042100:VERBOSE:Found krb5 stanza '[realms]
20140111042100:VERBOSE:Found krb5 compound statement ' DMOTT-LATITUDE-D530 = {
20140111042100:VERBOSE:Found krb5 name value pair ' auth_to_local = RULE:[1:$0\$1](^DMOTT-LATITUDE-D530\\.*)s/^DMOTT-LATITUDE-D530/DMOTT-LATITUDE-D530/
20140111042100:VERBOSE:Found krb5 name value pair ' auth_to_local = DEFAULT
20140111042100:VERBOSE:Found krb5 compound end ' }
20140111042100:VERBOSE:Found krb5 stanza '[appdefaults]
20140111042100:VERBOSE:Found krb5 compound statement ' pam = {
20140111042100:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530
20140111042100:VERBOSE:Found krb5 name value pair ' forwardable = true
20140111042100:VERBOSE:Found krb5 name value pair ' validate = true
20140111042100:VERBOSE:Found krb5 compound statement ' httpd = {
20140111042100:VERBOSE:Found krb5 name value pair ' reverse_mappings = (.*)@DMOTT-LATITUDE-D530 DMOTT-LATITUDE-D530\$1
20140111042100:INFO:Reading nsswitch file /etc/nsswitch.conf
20140111042100:ERROR:Unexpected file: /etc/lsb-release
20140111042100:INFO:Reading krb5 file /tmp/likewisetmpAQZy9o/etc/krb5.conf
20140111042100:VERBOSE:Found krb5 stanza '[libdefaults]
20140111042100:VERBOSE:Found krb5 name value pair ' default_realm = DMOTT-LATITUDE-D530
20140111042100:VERBOSE:Found krb5 name value pair ' default_tgs_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC
20140111042100:VERBOSE:Found krb5 name value pair ' default_tkt_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC
20140111042100:VERBOSE:Found krb5 name value pair ' preferred_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC
20140111042100:VERBOSE:Found krb5 name value pair ' dns_lookup_kdc = true
20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_kdc_hostname = <DNS>
20140111042100:INFO:Found config file /etc/ssh/ssh_config
20140111042100:INFO:Found binary /usr/bin/ssh
20140111042100:INFO:Reading ssh file /etc/ssh/ssh_config
20140111042100:INFO:Testing option GSSAPIAuthentication
20140111042100:INFO:Testing option GSSAPIDelegateCredentials
20140111042100:INFO:Running module join
20140111042101:ERROR:Unexpected file: /etc/lsb-release
20140111042303:INFO:Adding skula (fqdn skula.skull) to /etc/hosts ip 127.0.1.1, removing skula, skula.skull, skula, skula.skull
20140111042303:INFO:Reading krb5 file /tmp/likewisetmpSINKUa/etc/krb5.conf
20140111042303:VERBOSE:Found krb5 stanza '[libdefaults]
20140111042303:VERBOSE:Found krb5 name value pair ' default_realm = DMOTT-LATITUDE-D530
20140111042303:VERBOSE:Found krb5 name value pair ' default_tgs_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC
20140111042303:VERBOSE:Found krb5 name value pair ' default_tkt_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC
20140111042303:VERBOSE:Found krb5 name value pair ' preferred_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC
20140111042303:VERBOSE:Found krb5 name value pair ' dns_lookup_kdc = true
20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_kdc_hostname = <DNS>
20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_anchors = DIR:/var/lib/likewise/trusted_certs
20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_cert_match = &&<EKU>msScLogin<PRINCIPAL>
20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_eku_checking = kpServerAuth
20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_win2k_require_binding = false
20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_identities = PKCS11:/usr/lib/likewise-open/libpkcs11.so
20140111042303:VERBOSE:Found krb5 name value pair ' default_keytab_name = /etc/krb5.keytab
20140111042303:VERBOSE:Found krb5 stanza '[domain_realm]
20140111042303:VERBOSE:Found krb5 name value pair ' .dmott-latitude-d530 = DMOTT-LATITUDE-D530
20140111042303:VERBOSE:Found krb5 stanza '[realms]
20140111042303:VERBOSE:Found krb5 compound statement ' DMOTT-LATITUDE-D530 = {
20140111042303:VERBOSE:Found krb5 name value pair ' auth_to_local = RULE:[1:$0\$1](^DMOTT-LATITUDE-D530\\.*)s/^DMOTT-LATITUDE-D530/DMOTT-LATITUDE-D530/
20140111042303:VERBOSE:Found krb5 name value pair ' auth_to_local = DEFAULT
20140111042303:VERBOSE:Found krb5 compound end ' }
20140111042303:VERBOSE:Found krb5 stanza '[appdefaults]
20140111042303:VERBOSE:Found krb5 compound statement ' pam = {
20140111042303:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530
20140111042303:VERBOSE:Found krb5 name value pair ' forwardable = true
20140111042303:VERBOSE:Found krb5 name value pair ' validate = true
20140111042303:VERBOSE:Found krb5 compound statement ' httpd = {
20140111042303:VERBOSE:Found krb5 name value pair ' reverse_mappings = (.*)@DMOTT-LATITUDE-D530 DMOTT-LATITUDE-D530\$1
20140111042303:INFO:Reading nsswitch file /etc/nsswitch.conf
20140111042303:ERROR:Unexpected file: /etc/lsb-release
20140111042303:INFO:Reading krb5 file /tmp/likewisetmpU6alfc/etc/krb5.conf
20140111042303:INFO:Found config file /etc/ssh/ssh_config
20140111042303:INFO:Found binary /usr/bin/ssh
20140111042303:INFO:Reading ssh file /etc/ssh/ssh_config
20140111042303:INFO:Testing option GSSAPIAuthentication
20140111042303:INFO:Testing option GSSAPIDelegateCredentials
20140111042303:INFO:Running module join
20140111042304:ERROR:Unexpected file: /etc/lsb-releaseIn short I get the error "DNS_ERROR_BAD_PACKET A bad packet was received from a DNS server. Potentially the requested address does not exist." when I try just SKULL.
When I try with SKULL.LOCAL I get "Lsass Error Network name not found.. Failure to lookup a domain name ending in ".local" may be the result of configuring the local system's hostname resolution (or equivalent) to use Multi-cast DNS. Please refer to the Likewise manual at http://www.likewise.com/resources/documentation_library/manuals/open/likewise-open-guide.html#ConfigNsswitch for more information."
This is the only couple of problems I am having with this portion, I tried using a static DNS Server, Static IP... I even tried to do some research on this problem and still didn't budge anywhere. I also edited the resolv.conf file which lead no where. I want to expand my networking into linux as I gain more knowledge of the Windows Side of Networking
2. The next problem is adding my Network Printer. The configuration of my printer setup is with a Windows Print Server, I have installed all the required components on Windows Server 2008, which I don't know on the client side of things, but the error I get is "Bad device-uri "lpd://ADMINISTRATOR1/HP Deskjet D1400 series"." That is the only error I am getting right now. I went through Windows Firewall, and it has been allowed for LDP Service.
Any help will help me break ground on a little bit of Linux/Windows Networking.
