Linux bridge with multiple ports issue
Hi all,
my setup is the following:
ISP router/modem: 3x 1 gbps & 1x 5 gbps ports
Proxmox box: 3x 10gpbs ports
Windows 11 box: 2x 10 gbps ports
I have both computers connected to the router to have internet and have a direct connection between each other to have 10gbps.
Adding one of the two spare 10gbps nics from proxmox to the bridge (vmbr0) works great. Both proxmox and LXCs get 10gbps speeds connecting to Windows, tested it with iperf3.
The problem is with my TrueNAS Scale VM, I see it has the same vmbr0 bridge passed but in general I see 1gbps speeds when copying files from or to windows. I don’t know how to configure it so it choses the fastest nic in the bridge if available and I don’t even know what to look for to try fixing it.
I’m trying to avoid purchasing a 10gbps router because both machines are next to each other and I don’t have plans to have more wired connections.
/etc/network/interfaces
auto lo
iface lo inet loopback
iface enp1s0 inet manual
        pre-up /usr/sbin/ethtool -s enp1s0 advertise 0x1800000001028
iface enp35s0f0 inet manual
        pre-up /usr/sbin/ethtool -s enp35s0f0 advertise 0x1800000001028
#LAN
iface enp35s0f1 inet manual
        pre-up /usr/sbin/ethtool -s enp35s0f1 advertise 0x1800000001028
#LAN
auto vmbr0
iface vmbr0 inet static
        address 192.168.1.100/24
        gateway 192.168.1.254
        bridge-ports enp1s0 enp35s0f0
        bridge-stp off
        bridge-fd 0
source /etc/network/interfaces.d/*
TrueNAS Scale config
/etc/pve/qemu-server/103.conf
agent: 1
bios: ovmf
boot: order=scsi0;net0
cores: 4
cpu: host
efidisk0: vm-local-storage:vm-103-disk-0,efitype=4m,pre-enrolled-keys=1,size=1M
hostpci0: 0000:41:00,pcie=1
hostpci1: 0000:42:00,pcie=1
hostpci2: 0000:43:00,pcie=1
hostpci3: 0000:44:00,pcie=1
machine: q35
memory: 98304
meta: creation-qemu=9.0.2,ctime=1733007886
net0: virtio=BC:24:11:D0:79:33,bridge=vmbr0,firewall=1
numa: 0
onboot: 1
ostype: l26
scsi0: vm-local-storage:vm-103-disk-1,iothread=1,size=32G,ssd=1
scsihw: virtio-scsi-single
smbios1: uuid=dae4eaa5-28e8-4ef1-9c90-d25fca862dfe
sockets: 1
startup: order=1
vmgenid: a6c6b3be-2f0e-433b-bfee-f833ef722e8e
Thanks in advance
To make it more interesting, I just tested iperf3 between Windows and TrueNAS Scale (both ways) and I get close to 10gbps transfer speeds, so it seems the issue is with the VM and the bridge is working as expected.
I’m adding the truenas tag to the thread, to reflec this.
I guess this is not the right way of doing because I’m not getting any replies, I asked on the proxmox forum as well.
Most likely I’ll go with a router, but I’ll start a thread about that because everything networking is beyond me :slight_smile:
@tphon, you aren’t getting replies because you are not giving enough information for someone to figure out the issue. I guess your issues are that both computers don’t have enough PCI lanes, you have True Nas configured wrong, and you don’t have a switch.
It would help if you listed the specs of both computers to really understand what is going on. I would not purchase a new router but a 10Gb switch instead.
a linux bridge basically works like a network switch.
what virtual NIC is configured for your truenas VM? (not what bridge is it connected to)
sorry for the late reply.
Yes, I struggle to know what information to provide and I don’t want to create a wall of words, failing miserably. You are right, I was thinking of a switch but I said router :facepalm:
To describe my setup:
proxmox is a lenovo p720 with a threadripper 5945wx.
1x 10gbe AQC107 onboard
2x 10gbe intel X550-T2 nic
windows has a threadripper 5995wx with a gigabyte mc62-g40 motherboard
2x 10gbe intel X550 onboard
I solved it in a different way for now but it’s not ideal. I created a bond (as active-backup) with the 2 spare nics of the proxmox and added them to the bridge (vmbr0). Both are connected to the ones in the Windows box. It’s working fine, I get 10gbps but the downside is if I restart the proxmox I lose internet on the windows box.
on the truenas VM I see it as enp6s18. I don’t see any other configuration and the /etc/network/interfaces file doesn’t have anything, I guess truenas manages it in a different way.
right, using iperf3 between the truenas vm and windows I get the 10gbps as well both ways. If I copy a large file sometimes it starts way over the 1gbps threshold but a few seconds later (at most) comes down to 1gbps and stays there.
I guess because of the iperf3 I expect it to work but not sure
