Hello everyone. I’ve stumbled into an issue on both a Dell Venue Pro 11 7140 and Dell Latitude 13 7350 2in1. So the issue is after a fresh install of Debian 12 with Gnome and BlissOS (based on Android X86), which both use the 6.1 kernel… I don’t get any kind of sound coming out. In Debian when I go to the sound settings, the only output I get is dummy output. So I executed the lspci | grep Audio and it does list the Intel Broadwell Audio chip. I’m currently at a loss, I’ll add more details later
I did a search about the 7140 on lmgtfy.com and Reddit suggests that you need to add snd_intel_dspcfg.dsp_driver=3 to the kernel command line. In Debian 12, this lives in /etc/default/grub and you can add it to the GURB_CMDLINE_DEFAULT entry (leave a space after "quiet" so it reads GRUB_CMDLINE_LINUX_DEFAULT="quiet snd_intel_dspcfg.dsp_driver=3") and then run sudo update-grub as per https://wiki.debian.org/Grub#Configuring_GRUB_v2.
For the 7350, do you have error messages in sudo journalctl like this Device with ID register 0x... is not rt286 – there’s a patch that should be in 6.1 kernel to work with the control pin signaling of the sound chipset as per https://lore.kernel.org/all/[email protected]/ . Unfortunately, I don’t have a suggestion how to resolve this one.
K3n.
On my venue pro, that did the trick.
As for the 7350, I’m going to have to send it back to the seller; it seems to have a MASSIVE issue with ghost touch on the touch screen. Also even in Windows it’s having issues with the sound not working.
Hello, I also have one of these core m 5Y71 Latitude 7350 2in1 (there is a new model with the same name, also detachable but i’m referring to the old one) and I was trying to dual boot Windows 10 and a Linux distro. Eventually found one that the sound simply works, Fedora. Still get those ghost touches sometimes (after waking from sleep/suspend) but it gets fixed with a reboot. If you want to get sound on Windows the trick is to enter UEFI before booting it (as in if you are in Linux and want to change to Windows you have to Reboot to UEFI first not just reboot to grub). Same is true when changing from Windows to Linux. Sorry for the necro.
