Linux audio player like Logan's Foobar2000?
Is anyone able to configure an audio player in Linux like Logan did with Foobar2000?
The closest thing I found was Sayonara player but the website for it seems to be down
I was also looking at DeaDBeeF. I've been trying and trying to get it to look the same as Foobar2000 but can't. A quick google image search of DeaDBeeF and I see other options/setups I have no idea how people got them
Thanks
Thinking of switching from Windows. I'm very new to Linux, just trying it out right now and seeing if I can get out of it the same things I get from Windows. The biggest obstacle right now being a music player
You can get a little creative with Ncmpcpp if you use the terminal a lot
I like this one.
https://www.clementine-player.org/
Also, you can get Foobar working under linux. Getting access to your music (depending on where it's stored) isn't hard, in logan's case, it was on a NAS, and we had to do some under the hood network mapping.
Very cool. Thanks. Maybe when I'm more familiar with the terminal I'll give it a try
Foobar working through WINE, right? I might just end up doing that. I was hoping to use a Linux based music player but they just don't seem to look the same as the way Logan has Foobar and I can't get any of them to look like it either
Yeah, there are no programs "Like" Foobar. unfortunately.
I second clementine. If you're like me and use vanilla foobar on windows it gets the job done just the way I like it. Clean and out of the way.
Can't you get Foobar working via Wine? I thought that was how Logan ran it.
Try DeaDBeeF. It's probably the closest you'll get to a native Foobar clone and works well by its own rite. The plugin support isn't as large, but it's workable.
I really like Clementine and its QT goodness
Yup, that was the whole point of this thread :) To see if anyone has gotten DeaDBeeF(or anything else) to look like Foobar in the video posted above
Here is the deal.
Foobar through wine does not work the same way a native music player works.
Although you can enable things like wasapi or asio, it does not matter because you are still introducing a certain amount of latency with the wine layer.
So yes, it does work, but not as well as it would work on windows.
If you want something that has a similar lay out to logans player, then you need to be looking at banshee.
It has 3 main panels where you can choose from artist, album, and song.
The main drawback of banshee is that development is stupid slow. So it is not the prettiest nor is it the best functioning music player, but it is one of the easiest to manage.
The next one is tomahawk. It is very pretty, but it is a little bit more difficult to navigate.
Lastly the default gnome 3 music app works very well. It is very straight forward and does not leave too much to be desired.
It is basically itunes, except it actually works and does not get in your way.
Well, I'm sort of, kind of getting something that resembles it using DeaDBeeF
Imgur
I just need to fill in the three empty, grey areas with Genre, Artist, Albums
This is for Artist https://github.com/JesseFarebro/deadbeef-librarybrowser but I have no idea how to install it (still very new to Linux) but I'll keep trying to figure it out
If anyone out there has any suggestions on how to make DeaDBeeF look more like Foobar in the video posted above, it would be appreciated :)
there's clementine and deadbeef which can be configured like foobar
theres also foobnix (don't know if its still in development)
i personaly use audacious: (last time i used windows and foobar it looked similar to that for me)
