Hello level 1! I have decided to check out Fedora 26 as i have a spare ssd to use. Currently using Ubuntu 16.04. i am getting the screen I’ll share, and don’t know quite where to go from here. Is it my 970? I’m seeing some posts about troubles with Nvidia. I am hoping for a neater solution than swapping out the gpu, but if that’s what it takes, so be it.
Here is a pic of where it appears to stop. Not sure how long i left it like this before i rebooted and same same. Tried hitting enter, y enter, nothing. Thought maybe it would recover and get me to the install
Posting from my phone, be kind if the links don’t work.
Thanks in advance!
Quick update: swapped out gpu’s. Currently updating Fedora, installing chrome, steam… Will update again after Nvidia swap attempt
Double update: back on the nVidia card. marked solved THANK YOU.
