so im helping a friend build a computer and he thinks its suitable for an 850w power supply to be put in with these components no crossfire,sli am i in the wrong or is he right?(he isnt planning on crossfire mabye overclocking) but unlikely
I would say 850w is more than enough, would probably be fine with 550-650, but some people like to go way over as to make sure or to leave room for future upgrades. Also the hdd's / ssd's, disk drives, mobo, fans and other components will have a power footprint.
My cousin runs his amd 8350 / radeon 7850 with a 550w psu
Eh, why not. It'll probably of some better use to him later on, in new builds or upgrades if it doesn't break before that. It's not because it's overkill now that it'll be overkill in 2, 5, or more years.
AN Asus 760 and AN 8350 (1 GPU, 1 CPU), will never pull more than 400W, especially with no OC. A 360W PSU could easily that system, but I'd go for a 550W for sake of diversity in available options.
Well yeah 850W is massive overkill, 550/650W will be more then enough, but on the otherhand those XFX pro series fully modular are on great sales at the moment. XFX 850W 80+ gold fully modular for $125 after mir. or his little brother the 750W version for just $109 after mir, you can´t realy arguing for the price. ☺ but its still overkill.
You could power than on a XFX 450W. With overclocking and other considerations 500W maximum. I would grab the XFX 550W as a low cost, great quality option.
