Libvirt visrh ignores changes while saving
I am following this guide to enable Pipewire Jack for my VMs.
However, when I try to modify an XML, virsh ignores my changes and forces something else.
What I write:
  <audio id="1" type="jack">
    <input clientName="win10" connectPorts="Digital Input (S/PDIF)"/>
    <output clientName="win10" connectPorts="Digital Output (S/PDIF)"/>
  </audio>
  <sound model="ich9">
    <alias name="sound0"/>
  </sound>
What it saves:
    <sound model='ich9'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
    </sound>
    <audio id='1' type='jack'>
      <input clientName='win10-games' connectPorts='Digital Input (S/PDIF)'/>
      <output clientName='win10-games' connectPorts='Digital Output (S/PDIF)'/>
    </audio>
    <video>
Except that, I am getting error while saving:
error: XML document failed to validate against schema: Unable to validate doc against /usr/share/libvirt/schemas/domain.rng
Extra element features in interleave
Element domain failed to validate content
I select ‘ignore’ and supposedly it saves it. Double check the file in 3 different XML validation tools, and nothing is wrong…
I also tried via Virtual Machine Manage UI, and has the same bevavior. Tried to delete node, save and then create it like in the guide, still changes it to what I have above.
Any ideas why?
My full XML in case it helps:
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>win10-games</name>
  <uuid>51a536be-....</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit="KiB">33554432</memory>
  <currentMemory unit="KiB">33554432</currentMemory>
  <memoryBacking>
    <hugepages/>
    <nosharepages/>
    <locked/>
    <access mode="private"/>
    <allocation mode="immediate"/>
    <discard/>
  </memoryBacking>
  <vcpu placement="static">16</vcpu>
  <iothreads>2</iothreads>
  <cputune>
    <vcpupin vcpu="0" cpuset="0"/>
    <vcpupin vcpu="1" cpuset="16"/>
    <vcpupin vcpu="2" cpuset="1"/>
    <vcpupin vcpu="3" cpuset="17"/>
    <vcpupin vcpu="4" cpuset="2"/>
    <vcpupin vcpu="5" cpuset="18"/>
    <vcpupin vcpu="6" cpuset="3"/>
    <vcpupin vcpu="7" cpuset="19"/>
    <vcpupin vcpu="8" cpuset="4"/>
    <vcpupin vcpu="9" cpuset="20"/>
    <vcpupin vcpu="10" cpuset="5"/>
    <vcpupin vcpu="11" cpuset="21"/>
    <vcpupin vcpu="12" cpuset="6"/>
    <vcpupin vcpu="13" cpuset="22"/>
    <vcpupin vcpu="14" cpuset="7"/>
    <vcpupin vcpu="15" cpuset="23"/>
    <emulatorpin cpuset="15,31"/>
    <iothreadpin iothread="1" cpuset="13,29"/>
    <iothreadpin iothread="2" cpuset="14,30"/>
    <vcpusched vcpus="0" scheduler="rr" priority="1"/>
    <vcpusched vcpus="1" scheduler="rr" priority="1"/>
    <vcpusched vcpus="2" scheduler="rr" priority="1"/>
    <vcpusched vcpus="3" scheduler="rr" priority="1"/>
    <vcpusched vcpus="4" scheduler="rr" priority="1"/>
    <vcpusched vcpus="5" scheduler="rr" priority="1"/>
    <vcpusched vcpus="6" scheduler="rr" priority="1"/>
    <vcpusched vcpus="7" scheduler="rr" priority="1"/>
    <vcpusched vcpus="8" scheduler="rr" priority="1"/>
    <vcpusched vcpus="9" scheduler="rr" priority="1"/>
    <vcpusched vcpus="10" scheduler="rr" priority="1"/>
    <vcpusched vcpus="11" scheduler="rr" priority="1"/>
    <vcpusched vcpus="12" scheduler="rr" priority="1"/>
    <vcpusched vcpus="13" scheduler="rr" priority="1"/>
    <vcpusched vcpus="14" scheduler="rr" priority="1"/>
    <vcpusched vcpus="15" scheduler="rr" priority="1"/>
  </cputune>
  <os firmware="efi">
    <type arch="x86_64" machine="pc-q35-7.1">hvm</type>
    <firmware>
      <feature enabled="no" name="enrolled-keys"/>
      <feature enabled="no" name="secure-boot"/>
    </firmware>
    <loader readonly="yes" type="pflash">/usr/share/edk2/x64/OVMF_CODE.fd</loader>
    <nvram template="/usr/share/edk2/x64/OVMF_VARS.fd">/var/lib/libvirt/qemu/nvram/win10-games_VARS.fd</nvram>
    <smbios mode="host"/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode="passthrough">
      <relaxed state="on"/>
      <vapic state="on"/>
      <spinlocks state="on" retries="8191"/>
    </hyperv>
    <kvm>
      <hidden state="on"/>
    </kvm>
    <vmport state="off"/>
  </features>
  <cpu mode="host-passthrough" check="none" migratable="off">
    <topology sockets="1" dies="1" cores="8" threads="2"/>
    <cache mode="passthrough"/>
    <feature policy="require" name="topoext"/>
    <feature policy="require" name="svm"/>
    <feature policy="require" name="amd-stibp"/>
    <feature policy="disable" name="hypervisor"/>
  </cpu>
  <clock offset="localtime">
    <timer name="rtc" tickpolicy="catchup"/>
    <timer name="pit" tickpolicy="delay"/>
    <timer name="hpet" present="no"/>
    <timer name="tsc" present="yes" mode="native"/>
    <timer name="hypervclock" present="yes"/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled="no"/>
    <suspend-to-disk enabled="no"/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type="block" device="disk">
      <driver name="qemu" type="raw" cache="none" io="native"/>
      <source dev="/dev/sdb"/>
      <target dev="sdb" bus="sata"/>
      <boot order="1"/>
      <address type="drive" controller="0" bus="0" target="0" unit="1"/>
    </disk>
    <disk type="file" device="cdrom">
      <driver name="qemu" type="raw"/>
      <source file="/home/username/Downloads/Linux/virtio-win-0.1.229.iso"/>
      <target dev="sdd" bus="sata"/>
      <readonly/>
      <address type="drive" controller="0" bus="0" target="0" unit="3"/>
    </disk>
    <controller type="usb" index="0" model="qemu-xhci" ports="15">
      <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
    </controller>
    <controller type="pci" index="0" model="pcie-root"/>
    <controller type="pci" index="1" model="pcie-root-port">
      <model name="pcie-root-port"/>
      <target chassis="1" port="0x10"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="2" model="pcie-root-port">
      <target chassis="2" port="0x11"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
    </controller>
    <controller type="pci" index="3" model="pcie-root-port">
      <target chassis="3" port="0x12"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
    </controller>
    <controller type="pci" index="4" model="pcie-root-port">
      <target chassis="4" port="0x13"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
    </controller>
    <controller type="pci" index="5" model="pcie-root-port">
      <target chassis="5" port="0x14"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
    </controller>
    <controller type="pci" index="6" model="pcie-root-port">
      <target chassis="6" port="0x15"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
    </controller>
    <controller type="pci" index="7" model="pcie-root-port">
      <target chassis="7" port="0x16"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
    </controller>
    <controller type="pci" index="8" model="pcie-root-port">
      <target chassis="8" port="0x17"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
    </controller>
    <controller type="pci" index="9" model="pcie-root-port">
      <target chassis="9" port="0x18"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="10" model="pcie-root-port">
      <target chassis="10" port="0x19"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/>
    </controller>
    <controller type="pci" index="11" model="pcie-root-port">
      <target chassis="11" port="0x1a"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x2"/>
    </controller>
    <controller type="pci" index="12" model="pcie-root-port">
      <target chassis="12" port="0x1b"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x3"/>
    </controller>
    <controller type="pci" index="13" model="pcie-root-port">
      <target chassis="13" port="0x1c"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x4"/>
    </controller>
    <controller type="pci" index="14" model="pcie-root-port">
      <target chassis="14" port="0x1d"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x5"/>
    </controller>
    <controller type="pci" index="15" model="pcie-root-port">
      <target chassis="15" port="0x1e"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x6"/>
    </controller>
    <controller type="pci" index="16" model="pcie-to-pci-bridge">
      <model name="pcie-pci-bridge"/>
      <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
    </controller>
    <controller type="sata" index="0">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
    </controller>
    <controller type="virtio-serial" index="0">
      <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
    </controller>
    <serial type="pty">
      <target type="isa-serial" port="0">
        <model name="isa-serial"/>
      </target>
    </serial>
    <console type="pty">
      <target type="serial" port="0"/>
    </console>
    <channel type="spicevmc">
      <target type="virtio" name="com.redhat.spice.0"/>
      <address type="virtio-serial" controller="0" bus="0" port="1"/>
    </channel>
    <input type="mouse" bus="ps2"/>
    <input type="keyboard" bus="ps2"/>
    <graphics type="spice" autoport="yes">
      <listen type="address"/>
      <image compression="off"/>
    </graphics>
  </audio>
  </sound>
    <video>
      <model type="virtio" heads="1" primary="yes"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
    </video>
    <hostdev mode="subsystem" type="pci" managed="yes">
      <source>
        <address domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x03" slot="0x00" function="0x1"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x00" slot="0x14" function="0x0"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x10" slot="0x01" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
    </hostdev>
    <hostdev mode="subsystem" type="usb" managed="yes">
      <source>
        <vendor id="0x1e7d"/>
        <product id="0x2cb6"/>
      </source>
      <address type="usb" bus="0" port="1"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x0e" slot="0x00" function="0x0"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
    </hostdev>
    <redirdev bus="usb" type="spicevmc">
      <address type="usb" bus="0" port="2"/>
    </redirdev>
      <address type="usb" bus="0" port="3"/>
    </redirdev>
    <watchdog model="itco" action="reset"/>
    <memballoon model="virtio">
      <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
    </memballoon>
  </devices>
  <qemu:commandline>
    <qemu:env name="PIPEWIRE_RUNTIME_DIR" value="/run/user/1000"/>
    <qemu:env name="PIPEWIRE_LATENCY" value="512/48000"/>
  </qemu:commandline>
</domain>
Clearly you solved this (missing namespace) as you posted this:
If you solve the issue, please in future be sure to update a thread like this with the solution. When you create a thread on a forum asking a question like this, you have an onus to maintain it.
Actually I didn’t… I reverted all my changes, and it still ignores my changes if I try to edit it like above, but in Arch-Wiki follows another syntax which works… :flushed:
