Lian Li Tu100B Mini-ITX rig w/GTX 970
I found a mini-itx GTX 970 by Gigabyte so I decided to make a rig with it. I also wanted to use the Lian Li Tu100B that they used for the Colugo. What do you think?
http://pcpartpicker.com/user/fish20/saved/288xFT
I happen to like optical drives and you can just mount the two 2.5 inch drives on the bottom instead of one on the top and one at the bottom.
Why that motherboard? You could get the ASRock Z97E-ITX/ac for less money, but it has better reviews and is much more feature rich in my opinion.
I can vouch for that motherboard its absolutely awesome! I don't use the Wireless AC much since I am using the Intel NIC but the bluetooth comes in hand sometimes.
EDIT:
I had noticed this yesterday but when I went to my amazon purchase history, for some reason the images were that of the AsRock H97M-ITX/ac, but it could be just a glitch on amazon's part. The preview images are fine on Newegg.
