Considering it as my next case. Anything better at this price? I also want to know if this mobo is any good. I only like it because it's cheap and has ddr2 and ddr3 support.   http://www.newegg.com/Product/Product.aspx?Item=N82E16813153151 If I wait will I see more boards with ddr2 and ddr3 support?
If this is ur case http://www.newegg.com/Product/Product.aspx?Item=N82E16811112232&Tpk=lian%20li%20pc%2062Â then yes. IMO that thing looks ugly as shit. Try the CM storm scout, antec 902, haf 922. Also i heard that alot of ddr2/ddr3 mobos are that great. they tend to fail, at least from the asus one i think. P5QC?? :S
this is the case i assume: http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239&Tpk=lian%20li%20pc-k62
oh nvm then, that case looks sick. get it
hahaha I wouldn't consider that other case. Its either this or a stacker 830.
Nice posting man... Damn' I'm not moderator in this forum section.
When you get a white screen, it means it's posted.. dont refresh it 9000 times.
god damn. I didnt click shit it just sat there with its stupid rotating circle on the same page and i left it there
TAHT ONE!
