My ASRock Z68 Pro-3 M motherboard just finally ate it. So, I am left with my first CPU i5-2500k and 16gb of DDR3 that I would like to re-purpose into NAS duty. Thinking this U-NAS case would be a good option for me.
My question is, what motherboard would y’all recommend?
The front runner from a little bit of my shopping is the ASUS P8P67-M PRO. It has 7 sata ports (… not sure if I should be using onboard or getting a raid card…) advise would be appreciated.
Would probably just sell the parts and get a newer chip for a NAS. I wouldnt worry about sata ports you can always get an HBA card to add that will be way better then onboard if you decide to gothe reuse route.
Agreed. A Ryzen 3 1200 is probably on the same level performance wise but with less intel mitigation mess and current feature set. DDR4 is a little more expensive but overall you really wouldn’t pay much on top. If you do want to boost performance a bit, well there are options on AM4. And if you want to go ECC, you can do that too.
