LGA1150/H100i Case?
Hi, can somebody help me find a case that supports a h100i and can fit a LGA 1150 CPU socket motherboard. Cheers in advance :D
Additional info: Im not bothered about the cost but don't want a full tower such as 900D.
I'm beginning to wonder such case does not exist.
Assuming you're using an ATX form factor. Something like the Corsair 200R can be found cheap, or an NZXT 210 Elite. They have mounts on the top for two 120mm fans. You can mount the fans externally in a "pull" configuration. Both are mid-towers that will obviously fit micro-ATX motherboards, too.
You haven't stated anything about quality. Would you prefer a silent case? A chassis with air flow?
The HAF-X (Cooler Master) fits it fine but it's a full sized tower. I'm not sure of one that would do it without it being a full sized case honestly.
I would prefer a case with good airflow as i will be going for water cooling the CPU. apart from that not that fussed.
Corsair c70.
