LG Monitor (Dual Setup)
I will be gaming, watching HD videos, and some types of image editing and video manipulation.
I will also have two of these in a dual monitor setup, is the frame on the side too thick?
Anyway this seems like a pretty solid monitor, at a decent price, what do you guys think?
http://www.msy.com.au/product.jsp?productId=10780
http://www.lg.com/us/monitors/lg-24EA53V-P-led-monitor
You generally don't care about frames with two monitors. Frames are only in the way when you are gaming and games can't use two monitors.
Stand on this monitor looks like it can't rotate and I personally think it's very important to be able to turn one monitor to portrait in dual monitor setup.
I generally recommend Dell U2312HM in that price range. Aside from image quality, those have really good stands with adjustable height, tilt and rotation, which really helps when you have several monitors.
Thanks for your reply @Dissentient.
I don't mind rotation, it doesn't bug me.
I would go with the Dell U2312HM but the place I'm purchasing from doesn't have it. They have good prices, and going anywhere else would be to expensive and a hassle.
The monitors I'm looking at include;
http://www.msy.com.au/default.jsp?category=54
(Prices in AUD btw not USD)
Out of them I decided on the LG IPS 24" 24EA53V-P mainly because of it's price. It also has HDMI and DVI, which is what I need, other than that, I think it looks nice and has decent performance. So yeah I'll go with it. Now that I know the frame isn't a problem I'm set (unless there are any problems with it that I am not aware of).
Thanks.
Actually do you think I will be able to cheap out on a monitor since I will mainly be using it for gaming.
I could just go for one of the low end ones in this list.
for dual monitors, where they are identical, I don't really see any reason for displays larger than 23". But you can take your pick from here:
http://au.pcpartpicker.com/parts/monitor/#s=2900,2410,2400,2380,2360,2300&sort=a9&p=1
I really distrust any technology-purveyor that doesn't understand how to make a website that won't stretch the images.
I don't like viewsonic, and although AOC makes a pretty monitor, the stock color gamut is really weak. I suspect some fiddling about in the settings could fix it, since many of the panels are the same anyway. LG, Asus, Dell are all great brands for monitors.
