heres the short version, ive got a shop owner that we got a levono system for a year or so ago, it came with a 500gb hdd its been high time that we slop an ssd in there.
so i did just that, we cloned and migrated his C: to the ssd.
heres the catch, IF the original HDD is REMOVED from the system. the power to the system will just POOF and die about every 15 or so minutes. no blue screen no error log, poof black and reboot.
i had thought, thats impossible to be the cause from a disk drive, you can yank a disk drive out during operation and itll just buffer out then bluescreen on windows.
but for the hell of it, i sent back the ssd, and got a replacement ssd (samsung 500gb 850 pro)
this time i left the old drive set the bios to boot to the ssd. and removed the dvd player as the mobo only has 2x sata ports.
the system ran flawless for 2 weeks.
TODAY, i took the old hdd OUT, and put the dvd back in. and low and behold. the system just up and kills power to itself.
my ONLY remote IDEA, is that the 18 WATT difference .... (going on a limb here) that 18 watts is just enough on the threshold that the psu (250wmax) thinks the system is off? ???? and thus decides to stop supplying juice to the system
thats the ONNNLLLY PLAUSABLE idea
unless levono is just being a righteous cunt and found some way to lock their hardware into the system ??
you can use another power supply but it won't be easy. 1st check to see the wires on the psu are correctly color coded. if it's not like the image above then you'll need to use a voltmeter to find the pinout. then get a atx extension cable and re-pin the moulex connector to match the pinout of the lenovo.
that said I would say it's only worth it if the system is running a i5-2500k or somthing like that. other wise putting an expensive SSD in it is just a waste.
the person that owns that store is tired of waiting 5 minutes to boot up Not to mention waiting on any of the miscellaneous crap that he has to load up Microsoft Outlook Excel stuff and what not X cetera
I guarantee you guys do not even remember the horrors of living life before solid state drives
Even trying to open Google Chrome and navigate to YouTube on that old 500 gig hard drive was a nightmare
Getting anything done on that old drive even though the processor still has horsepower in spades
When I have something other than my cell phone at my disposal I will go through my order history and link the exact model of that computer although it is listed in the photograph on my first post
Hmm think I've worked on one of these if not something very similar. IIRC the power supplies are a royal pain in the ass to replace, pretty much had to disassemble everything to fit it in. But I think we found a dell 250w power supply out of a slim dell tower and it worked just fine.
When stock hdd is Not connected. System shuts down every ten-fifteen minutes In such a manor that is inconsistent with anything except a power outtage
It was just purely theoretical in my mind
that possibly the lower 18 watt consumption would throw the power supply into confusion and make it , Assume the computer was trying to enter a sleep state so therefore the power supply would shut off
Odd, I always replace the drives if they have been running over a certain amount of hours, but can't say if I had this happen before on that particular desktop.
I have not , tried a new psu, I don't really see a point we have basically skirted around the issue by ignoring it completely and leaving the stock unit still connected to the motherboard
I will forever be in the X200 Thinkpad masterrace cult But their recent products of the last two years or so? Nonononono HELL NO, I'd rather buy HP or Dell
After my IBM 600X I got a Lenovo B575 (I got the 600X through fixing it in high school and it ended up my main laptop after my desktop [an HP EVO D510] and laptop [HP NW8000] died at the exact same time) which rocked my world. Dual core?! What! More than 1024X768?!?!?!? I mean, yeah the HP had 1600X1200 but it wasn't widescreen O:
My mind was blown and I still have that laptop. It runs great.
Edit: With 4GB ram I can run skyrim on an E-450 APU at medium settings with good FPS for NO REASON. It confuses me but ugh <3
yea thad be awesome, its not EVERY 10-15 minutes , but if you can just use the thing open a window and if when you come back, its not open, then the system did a reboot while you were not babysitting it
