Currently I’m in the process of opening our new store which specialises in used gaming computer. In the center of the store there will be dual monitor high end gaming setup on which customers will be able to try gaming pcs at different price ranges. For this setup to work I need a kvm switch on which 4k 120hz gsync will work. I would like to buy level1techs kvm but I don’t where to get since the store says there is no stock. I would order it in a hearth beat if 1pc could be ordered.
If that is no chance to order level1techs kvm I would ask you to recommend any other kvms that would be suitable for my use case.
image of this settup (only 4 computer will be hooked up)
