Hi, I have the 1.4 DP 4-Port KVM and I have an Anker USB 3.0 hub connected to the back USB 3.0 port. I tried setting up another Anker USB 3.0 hub using the front USB 3.0 port and it didn’t see the devices I connected and also disconnected the ones from the other hub. Are the Anker hubs conflicting with each other? Thanks.
Hi thank you for reaching out! I moved your post to Level1 Store → KVM Helpdesk.
Hmmmm. Not sure. I don’t think I’ve seen this issue before. @wendell ?
