What cables are you using and what resolution/refresh rate/bit depth is your display?
Also, if you add up the length of all the cables in a single “run” (PC to KVM, KVM to display) how long is it?
You need to keep the total run length under 4M for the best signal quality, and you also need to use high quality cables. (Club3d are best, but the ones sold on Level1 store are a close second)
Awesome! I noticed after switching my cables on the Mac it worked better. Now the pc is being weird but those cables are older and longer. So I’ll buy some new cables to replace them.
