I bought the KVM from Level1 and when I switch to my laptop - no problem. When I switch to my Desktop - the screens flash 2 times, every time.
I do not think it is the cables, I bought 2 sets of the Level1 cables and have a set of Club3D DisplayPort 1.4 HBR3 32.4gbs, 8k, 60hz cables. I also used the Level1 cables for the desktop to KVM to Screens.
I am thinking perhaps it is a setting? Refresh rate? Resolution? One of the Manage 3D settings? - I just don’t want to be messing with too much of it if someone knows the fix?
I am running this through a 2080ti, it is 2560x1440 native screens and running at 60hz. These are LG 27GL850 monitors.
If it helps with diagnosis, it also moves items from Screen 2 to Screen 1 - almost as if it is detecting 1 screen first and then treating it as a 1 screen display - and then detecting screen 2 afterwards. Then flashes a couple of times - also moves the mouse to the centre of the screen.
You might try persistent windows to keep the display things in place even if the monitors are detected in the wrong order on one of the PCs.
On the LG osd in the monitor see if you have a deep sleep option. That should be set to off. Sometimes you might have a dp 1.1 or dp1.2 mode. You should toggle that option and see if it makes a difference. I have the ulrrawide of 3840x1600 display and it ships with dp1.2 mode on which when you turn off the display works better.
If you have energy saver in the osd turning that off helps too.
The second flashing may be because one monitor is taking a lot longer than the other to respond properly. So the computer says oh one display got it. Then it seems the other display and that’s the 2nd flash.
