Hi Everyone,
I have a 1.4 Display Port KVM Switch - Dual Monitor - Two Computer model, with a PC and a Mac studio. I have two Samsung S32D850T 32" LED LCD monitors, are they are connected via DP 1.4 (Capshi DisplayPort Cable 1.4, 8K DP Cable 6.6FT, Amazon) and from Mac to KVM via Thunderbolt to DP ( Warrky USB C to DisplayPort Cable). There are a couple of issues I am facing:
PC to Mac display loss: If I wake up the Mac studio from sleep, it wakes up and the display is there. If I switch to PC, the PC also wakes up (the windows are not organized as before). But if I switch back to Mac, I do not get any display. However, if I switch after the sleep time of Mac, the display is connected again. In order to get the Mac display to connect again, I have to switch the thunderbolt ports on the back of the Mac and then everything reconnects. Am I missing something here with the Mac thunderbolt to DP connection?
Mic issues: I have a Logitech Brio, and I get feedback issues on the Mac. I have tried multiple different mics and every time its the same feedback issues with different virtual call platforms (zoom, teams, discord). There are no issues on the Mac.
Would you suggest any solutions for the problems above.
