LED Strips help
Hello Tek community,
I'd like to know what strips could I use to stick on the back of my montior (red led strips) and which ones to stick inside my pc. Any tips? The ones I;ve found on amazon just dont please my needings, thank you.
BitFenix makes some good ones. Or, if you don't like those, just solder together some LEDs of your own and put them in whatever sleeving/cover you want.
I want them to be quick install, open the package, stick them in the back of the monitor and done
