Leaving Console, Joining PC
Building my first rig, and looking at keeping it relatively cheap. I may have screwed up in some parts of this, so CONSTRUCTIVE criticism would be appreciated.
Case Fans: (4) Enermax T.B.Silence 120mm LED Twister Cooling Fans
CPU Cooling: NO IDEA WHAT I"M DOING WHEN IT COMES TO CPU COOLING!!!
Memory: 1x8gb Patriot 1333MHz DIMM
Power Supply: Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS (CX600)
HDD: Western Digital Cavair Blue 500Gb SATA III 7200rpm (16mb cache)
Graphics: Force3D AMD ATI radeon HD 6450 2Gb DDR3 HDMI DVI VGA video graphics card PCI express pcie x16 HD 1080P windows 7/vista/XP (I copy/pasted for specification)
Processor: AMD Athlon II X2 270 Regor 3.4 GHz 2x1 MB L2 Cache Socket AM3 65W Dual-CoreDesktop Processor - Retail ADX270OCGMBOX (Copy/Pasted)
Motherboard:Gigabyte AM3+ AMD DDR3 1333 760G Micro ATX Motherboard GA-78LMT-S2 (Copy/Pasted)
Case: Thermaltake V3 Black AMD Edition Gaming Chassis Mid Tower Steel Computer Case VL800P1W2N
I also have no idea what to do for the soundcard, since it is also a concept I cannot grasp. I'm going for a somewhat cheap build here..
Also, I'm going for newer games, Like Bioshock and Crysis. I really hope this can run them.
How much are you willing to spend?
if you're talking about crysis 3, woowee you're going to need something pretty damn powerful
as said before, whats your budget?
Ummmmmmmmmmmmmmmmmmmmmmmmmmm.
Post a budget and let someone else do this. Lol.
I don't even know how well this would run Half Life 2.......
You need a very very high end system to max crysis, let alone run it.
But I assume you're on a really tight budget. Grab something like this; http://pcpartpicker.com/p/PHwf
For 400$ you should be able to at least PLAY nearly any game. Not counting crysis and other intense games though. Could switch to a 7750 for some exter' performance. Usually you can find a 7770 for around 90$ though!
yes please give some budget. cause for crisis 3 you need  better then this  realy.
if you realy wantto play the newest games like crysis 3 BF3 bioshock etc then think about something like this. to start, this is able to play all new games on high. notice you can allways decide later, wenn you update the motherboard bios, to upgrade the cpu to a FX6300 or FX8350 in the future. but you cant do any overclocking on this motherboard, but if you never attempting doing overclocking its a good board.
http://pcpartpicker.com/p/PHCF
grtz Angel .
My max budget is $450. I was thinking this would be a decent run until my financial situation is a bit better.
okay thanks lets see what we can make of it ☺
do you maybe have some hardware  you can use, like a sata harddrive?
And, I really appreciate the help.
I do not have any available hardwar, as my current setup is.. less than impressive.
okay next try
http://pcpartpicker.com/p/PHPU
i dont knowhow it works with those  rebates and stuff but  if you take tha advaniced of it you can have this for 464 dollar. most games must be playable on this eaven Crysis 3 at mid settings. and maybe eaven high if you put some filters back to medium settings.
Nice GPU pick. Lol.
They make even cheaper cases; get whatever is the a absolute cheapest, and get a little more than 4GB of memory (maybe a 2x4GB kit) that way you won't have to throw that RAM out when you upgrade.
Looks impressive. I'm not sure about the rebates either, never been comfortable with them. But, I should be able to swing that.
that red amd case looks very cool, i gues thats the case you suggested in youre start post, so i kept it in, ofc there are cheaper cases to get, but this case looks awesome.
about the gpu, yes it looks cool, for that price it was the nicest looking card i could find about looks and specs. other cards look realy horrible.
so im guessing you dont need an OS or monitor? the 450 budget is tower componets strictly right?
Take 2: http://pcpartpicker.com/p/PI1t
Probably the best you can possibly get for the money. I have rebates off along with a few sites that don't include shipping in their prices or I just don't really wanna buy from. Since it's AM3 you can switch to a piledriver or even the next series of AMD chips once you find it necessary or build the funds. You won't need a ram upgrade, and a 7770 is honestly not a bad card. Sure it will probably not be for Crysis or anything, but it WILL be able to at least play most games and could probably play Bf3 on high/max settings. The CPU will of course hold some small drawbacks, but it fits the 7770 perfect.
For some reason RAM costs a ton more now.
I took out the PSU. I have one to put in (I just remembered) , after that, I had a bit of wiggle room. This is what I developed. (not ignoring yours, just trying to see my options.) Feedback?
http://pcpartpicker.com/p/PI3u
I have windows 7, and my tv will be my monitor. And yes, tower components only.
I agree. RAM used to have a max of $100, now we're looking at upwards of $200!
