GA-990FXA-UD5 (rev 1)
FX-6300 (Be Quiet! Shadow Rock 2)
GTX 760 4gb (water cooled)
Viper Xtreme 8GB RAM
Thermaltake Toughpower 750 watt gold
Windows 7
NOTE: part of this thread is that I'm asking if there are any comprehensive sources that already exist that should be mentioned. For some reason, I'm not finding much with our search feature here. I'm unsure if I'm missing something obvious or... As I say below, I often use JayzTwoCents and others as a reference, but I know of no comprehensive, educational video where someone talks you through what everything in the BIOS is and WHY it matters to overclocking. I only see a ton of guides for various mobos and CPUs combinations. I've answered a lot of my own questions, but there's a lot I still don't know and I'm sure somebody else can use the info too. If anyone knows of comprehensive sources, please share them with your fellow noobs.
I've avoided overclocking for a long while now because of ignorance and fear of frying hardware I couldn't afford to replace. Many videos and articles later, along with aftermarket cooling, I'm trying to learn it now, even if I decide to not really do it. Any enthusiast should at least know.
MSI afterburner has given me some... mild FPS increases here and there, but stability hasn't been perfect. So for the time being, I'm just trying to learn CPU OCing. Today, I've OCed my 6300 to 4.0GHz using JayzTwoCents work as a reference so I don't forget anything. After some voltage changes, Prime95 is giving me a thumbs up. But Heaven benchmark is still acting very weird... You know how it's supposed to pan slowly and smoothly? It's been flying through the scenes like a bat out of hell. In game testing is still less than perfect, but better. Also, when I turn on or restart my computer now, it starts to turn on, seems to die, waits for a second, and then actually turns on (restarting isn't a smooth transition where the LEDs and fans stay on anymore either, it's an abrupt off, as if I had selected shut down, followed by that die and restart I just described). This is very similar to something that happened to me with a shoddy power supply in the past, but since I have that new (as in, yesterday) 750 watt gold PSU and it started immediately after OCing the CPU, I'm sure that's it. Also, even though I've turned Cool and Quiet, etc back on, variable voltage/clock speed regulation seems to not be working (no high temps though ,so..?). This is a minor point, but my smooth transition wallpaper slideshow turned into abrupt picture changes again after OCing.
This is a lot to read, but I wanted to describe the odd experiences that I, and I assume other people new to overclocking, have had. What should I/we do if these kind of things come up? Is there some source we can use for troubleshooting these obscure problems? Many thanks to anyone taking the time to read this. Send anybody having similar problems here if we have an answer.
