Hi guys, i want a computer to run league of legends on maxed settings and over 60 fps. What should I buy for this awesome computer, please help me:)!
(I want to keep it as cheap as possible but I dont want an crappy computer)
Thankyou and cya^^
Thankyou and cya^^
That will around $400 and will play the game perfectly. You can add a GPU down the road and extend the life even more. If you want more power now you can just add a 7870: http://amzn.to/13iTSl2. I prefer that to the dual GPU solution with that CPU.
For LOL you just need a decent graphics card to get above 60 fps. The games cartoony engine was built to not be cpu dependent and offer a wide range of computers access to the game. This is part of why its so popular. You could run a dual core with a 650ti or 7850 to massively exceed your goal (think 90+ fps). If you want to stream on twitch or google then you'd need a quad cpu to be able to accomomdate both.
Well I was thinking about 450 euros. Thanks for the options logan, but the extra 210 bucks for the video card is a little bit to much for me haha. I think it is so hard to choose which components to get because if I look this up on youtube, there are too many builds, and ofcourse I want the best for my money. So something like 450 euros, LoL with more than 60 fps standard. Is this enough info for some more tips^^?
Buy a second hand Core 2 duo or sandy-bridge dual core and at least a gtx 460/gtx 550 or hd 6850/7770 and 4gb 1600 ddr3 ram of any brand and you're set.
