LCD Response Time questions
Hi guys, ;)
1) Do you think 5ms response time would be fast enough for gaming and HD movies or 2ms really make a difference?
2) If there is tow monitors with different response times running in dual monitor mode would be there a noticeable speed variation?
the ghosting starts below 8ms so 8ms and 2ms wont make a big difference.
Im gonna add that i have a 20" LG Widescreen LCD which has 5ms and i dunt see any ghosting what so ever.
do you see any difference between DVI and VGA?
The point about all this I'm thinking about buying this monitor [url=http://www.nec-display-solutions.se/c/g/se/sv/Products/Details/Specification/dp/Products/LCD/Current/LCD-LCD22WV/LCD-LCD22WV/index,group=all.html] NEC 22WV[/url] It's available for about 200$
and pleas don't suggest any alternatives I don't live in the us so I don't have so many good deals :(
Its better to go with DVI but if u do not have a choice to go with DVI then VGA is a good alternative.
no difference, only that dvi can get higher resolutions for bigger monitors, you could try it with both cables htough
there is almost no visible difference between 5ms and 2ms to the eye both are fine but go with DVI because VGA is out of date
