Latop for 3D and CAD
Hello everybody,
Since I've begun college, I've noticed my old laptop (Samsung R440 with i3) is no longer sufficient for the stuff I`m working on. Mostly due to rendering and gaming in medium settings. What laptop would you recommend that would fit the requirements:
Budget: $600 - $800 USD
Specs:
HDD Space: 500 - 750GB
RAM: 6GB at least
Software that will be used:
Solidworks 2013
AutoCAD
Autodesk Inventor
NX8
Photoshop CS5
Games:
Dead Space 2
Saints Row 3
Portal
Half-Life 2
Borderlands
Final notes:
Can't order online, due to problems with mail delivery in my country (Mexico, stuff always gets stolen)
Not sure if AMD APU or discrete Graphics Card would be better.
Thanks in advance.
For solid works i know someone who used a low end quadro for that... But any computer with a decent graphics card (depending on the models you work with) and an I5/7 or an FX 8350 will run both games and productivity fine.
I ran autodesk with integrated graphics from a i5 2430m.  Worked alright. I only had issues with ray-tracing and some visual stress analysts.  For gaming, i could barely run CSS at playable fps.  I would go with something with a discrete gpu.
