Hi,
I am thinking about buying used. I can get a Dell Latitude E6220 for 50 bucks.
The specs:
i5 second gen, 4GB, no HDD (have own 7200rpm drive)
The use case:
putting Linux back on bare-metal, internet, mail, youtube on the go, throwing it in a bag and don’t worry as I do with my current 15-inch gaming laptop
That use case would be fine for that laptop. Second gen mobile i5 is fine still for basic use.
The price is good as long as it’s in good condition. Fully functional 6220’s on ebay with a hard drive and Windows are easily twice that in price.
4GB RAM may be a bit tight. I can’t remember if those smaller systems have two DIMMS or not. Putting a spinning drive in there won’t do you any favors either. SSD’s are pretty cheap now.
For $50? Best you’re going to get! But, I’d just like to let you know that Latitudes certainly aren’t Dell’s best built lineup. They are more of the runt of their business class lineup. I had an E5530 for 5 years. At year 3, with regular work, it gave in. Not the actual hardware, but the frame of the laptop. It was cheap plastic and the CPU would get rather hot causing it to crack on its own over time.
That said, I loved the laptop for these reasons:
The keyboard. Only other laptop with a keyboard as great would be a ThinkPad.
Pretty easy to expand. You remove the bottom panel and the components are just there. No other work required. The inside is generally spacious as well.
They are decently rugged for what they are. Like I said, even when my frame started to have issues, I didn’t get rid of it until I started to have severely bad and unfixible thermal problems (replaced the paste, clean the heatsink, no luck). Given that I literally use my laptop 3-4 hours a day, it’s pretty justified. But nothing will best a ThinkPad.
My BIGGEST issue was the Broadcomm WiFi chipset. It was a horror on Linux until recently.
Thank you for the replies. I was set on to get one, but my co-workers managed to ramp up the prices on the auctions to 100 bucks already and that is a price I am not willing to pay for the most beat up model. The price tripled for the best persevered laptop…
Thanks for the offer, but I think I will just buy a bigger SSD and dual-boot for the time beeing. The forums got me interested in Linux again, maybe I will join the 1 year chalenge.
I will try to get the 1 gen newer Latitude next year Maybe I will have more luck then.
thats a decent price for a workhorse like that , maybe not so much for gaming but theres a lot of things you can do with it.
installing forensic distros come to mind!
