MattiP
August 18, 2024, 8:08pm
1
Found these two on Ali and they use ASMedia1064 and ASMedia1182E as controllers. Anyone happen to know how much they increase latency? I was thinking of using them as cache disks were raw throughput is less important. They’re of course not as good as the PEX chips, but both these cards are like $25 which is a looot cheper.
Not the one below.
diizzy
August 18, 2024, 8:11pm
2
ASM1064 is a SATA-controller and a rather old one
MattiP
August 18, 2024, 8:44pm
3
Ah yes, the quad card is for sata only. Thanks for pointing out.
diizzy
August 18, 2024, 8:46pm
4
Just get a ASM1164 / ASM1166 based one and be done with it?
MattiP
August 18, 2024, 8:57pm
5
It’s the x1 nvme controller I want mainly, to put something in those x1 slots.
diizzy
August 18, 2024, 9:48pm
6
MattiP
August 18, 2024, 10:20pm
7
For two nvme, like the one in the first post.
https://www.asmedia.com.tw/product/213yQcasx8gNAzS4/b7FyQBCxz2URbzg0
It’s PCIe 2.0 = 5 Gbit/s, i.e. a bit slower than SATA.
PS. A board like this is 3.0/4.0, so if your motherboard supports higher speeds, you could use one NVMe at 8 or 16 Gbit/s at an even lower price. https://www.aliexpress.com/item/1005005924920287.html
system
Closed
May 20, 2025, 3:02am
9
