laptop recommendation
General Questions
  1. What is your budget? ~2000
  2. What size notebook would you prefer?
    a. Netbook; 10" screen or less
    b. Ultraportable; 11" - 12" screen
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    e. Desktop Replacement; 17"+ screen
  3. Where will you buying this notebook? You can select the flag of your country as an indicator.
    US - online
  4. Are there any brands that you prefer or any you really don’t like?
    a. Like:
    b. Dislike: Dell - had a bad experience with back in 2006, im hesitant to buy a dell but ive heard they have gotten better so i may be willing to buy dell
  5. Would you consider laptops that are refurbished/redistributed? No
  6. What are the primary tasks will you be performing with this notebook? Programming, photo editing(photoshop and lightroom) and running 2-4 VMs
  7. Will you be taking the notebook with you to different places, leaving it on your desk or both? Mostly desk and around the house, weight isnt an issue
  8. Will you be playing games on your notebook? If so, please state which games or types of games? No, probably not
  9. How many hours of battery life do you need? 5+ would be great, but not a deal breaker
  10. Would you prefer to see the notebooks you’re considering before purchasing it or buying a notebook on-line without seeing it is OK? Buying online us ok
  11. What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    I will be installing linux
Screen Specifics
  1. From the choices below, what screen resolution(s) would you prefer? 1080 min, would like higher resolution, looking at 4k
  2. Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.) No preference
Build Quality and Design
  1. Are the notebook’s looks and stylishness important to you? No as long as it doesn’t look over gamery and has good build quality
  2. When are you buying this laptop? Would like to buy soon, but willing to wait.
Notebook Components
  1. How much hard drive space do you need? Do you want a SSD drive? SSD 512gb min
  2. Do you need an optical drive? If yes, a DVD Burner, Blu-ray Reader or Blu-Ray Burner? No
Laptops ive considered
Dell xps 15 w/ 4k screen (Price 8750h, 4k, 1050, 512gb ~1800 + tax)
- worried about ssd performance
- i can buy a new 512gb samsung 970 pro for the price to upgrade 256 to 512 ssd on through dell
-thin laptop w 6c/12t processor for VMs
Lenovo Yoga 920 w/ 4k screen (8550u 4k, 1tb ssd ~1600 + tax)
- Worried about the 360 hinge wearing out and poor wifi performance
- worried about 8550u powerful enough running a few VMs
MSI gs65
Not a fan of the inverted motherboard
Seen review of poor build quality
Like 2 m.2
Pro - 6c/12t processor
Razer 15 (1080p 144hz, 8750, 512gb, ~2600)
Heat
Price
4k option is too expensive
Gigabyte areo 15x (8750, 4k, 1070, 512gb, ~2500)
Pro - Has 2 m.2
@KemoKa73 has a thinkpad that you might look at
Dell has been great since they went back to being a private company. 2006 was when they were public.
I would suggest to take a look into SAGER/CLEVO, a good place that has a ton of options XoticPC.
Now you seem to be more interested on a more powerful cpu, and even though you dont game nor plan to, in case you want a 8 core, check ASUS ROG STRIX GL702ZC
People are programming and doing photo editing on mac air 13. Pretty sure you can use anything with a half decent screen.
