I have a hp pavilion dv2807nr laptop that overheats with light use( The cpu right now is at 160F). I took apart the laptop to see if it was loaded up with dust and it was fairly clean. I am sick of having my leg burnt and do not know how to fix this issue. Any thoughts?
even more likely it is the gpu, in that case get some longer screws for the heatsink, and copper shims. these things have gpu problems very similar to the xbox 360
The ribbons conectors on this laptop have 2 things on each side that you push out on each side to losen it. It is a standard connector for the motherboard I think.
How hot does it actually get? 160F is not uncommon for a laptop. My old HP laptop regularly hit 182F while on any sort of load whatsoever. Then when I got my Asus G72 it would hit a few degrees higher (194F). If your CPU temps are staying under 195 then there probably isn't anything wrong with it.
There was a blue thermal pad on the gpu and Some crappy looking thermal paste on the CPU. I cleaned both surfaces and put artic silver on. Is there any way I can test to see if everything is working and I did not break anything?
The air coming out of the laptop is cooler and the fan is not always on full blast but the cpu right now it at 171F. I followed there guide on how to apply thermal paste so i'm 99% sure that it is on correctly.
