I recently bought a crappy HP laptop with an AMD dGPU inside.
I have started noticing that whenever Arch Linux (GNOME) turns off the monitor, it goes completely dark, then gets a slight green tint but with no backlight for about 4 seconds, then goes back to black and then loops forever. This only happens when the machine is in standby (everything is running but monitor is turned off). While in suspend & powered off, the monitor has a constant green tint like the one mentionted.
Don’t know if it is a software issue because I did not have anything apart from arch on this machine. I have not found anything about this on the internet.
Is this bad? It doesn’t worry me that much but I would like to know if it’s something that I should be concerned about or not, and I was wondering whether any of you had the same issue / thing.
Will upload video if necessary.
Thanks for your time.
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000000
XKB indicators:
00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 500 repeat rate: 33
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 0 cycle: 0
Colors:
default colormap: 0x20 BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
/usr/share/fonts/misc/,/usr/share/fonts/TTF/,/usr/share/fonts/OTF/,/usr/share/fonts/100dpi/,/usr/share fonts/75dpi/,built-ins
DPMS (Energy Star):
Standby: 0 Suspend: 0 Off: 0
DPMS is Enabled
Monitor is On
I am using the latest stable AMDGPU drivers with Xorg, kernel 4.13.12-1-ARCH.
Can’t see this being asked anywhere and I don’t think that it’s something to do with overheating because my temps are constantly +50C under threshold, and the fan rarely even spins up. Plus the actual image quality doesn’t ever suffer at all.
I’m pretty sure this is not even an issue, probably giving it more thought than it even deserves, thanks for your response though.
