Laptop memory for Framwork
Hey I am looking for help with buying memory for my soon to come Framwork laptop. I am debating between 32 and 64 gb. So far I’m looking at G.SKILL Ripjaws and Mushkin Enhanced Redline.
What workload(s) are you intending to run on the device? Day to day computing (browsers, video, office docs)? Video editing? etc.
Both are likely to be fine. Ditto for Crucial / Micron or SK Hynix.
Both day to day as well as 3d modeling, cad work and a little side gaming.
I feel like I over bought on RAM by having 64GB on a gaming-only machine. But given that is not all you’re doing, I’d err towards having more, personally.
On the other hand, the sensible answer would be ‘run your workloads on your current machine and check the RAM usage, then buy appropriately’. Depends on how much overkill you like, from there. :slightly_smiling_face:
I’ve got 64 GiB in my Linux gaming system as well. It’s an overkill for gaming, but very nice for memory intensive applications.
For what Framework model do you need the memory? Do you need DDR4 or DDR5 for the new AMD versions? Me personally, on the 11 generation Intel that I got with one of the first batches, I got 32(2x16)GB of G.Skill Ripjaws with 3200MTs. I recently upgraded to AMD and got myself 64(2x32)GB of Kingston FURY Impact with 5600MTs. I like to always have enough memory, especially since I have advanced future plans for the machine, and the extra cost was not much of an issue for me.
Thanks for the input it has helped me make a chose.
You’re welcome, will you enlighten us, what did you choose? We need closure!
Sorry, I went with 64g of G.skill for added head room (also it went on sale). It will be for the new Framwork16 when I get it.
Late to the party, but for anyone else with a similar question, I’m running this SSD (full 4TB usable, no stability problems, working fine) https://www.amazon.com/gp/product/B0B7CQ2CHH/
and this ram kit: https://www.amazon.com/gp/product/B0C64CFW4B/ (64GB at DDR5-5600, stable, no issues or adjustments)
Works awesome for some mobile KVM host tinkering.
I’m using it on a 13, but the 16 should perform the same. You’ll need to locate your own recommend for the 2230 sized slot, though.
(edit, fixed SSD link)
I think both links link to the RAM, none to the SSD!
Whoops!
I haven’t tested my 2TB WD850Xs, but since they’re the same chipset/firmware, just different flash size, I’d imagine the 1TB and 2TB ones work equally well.
