Hey, now let's talk about laptops.
I have a Toshiba Satellite L755-167 that I've had for 1.5 years. It has worked just fine until kinda recently. I tried logging into my profile when a message showed up saying ''The user profile service failed the logon. User profile cannot be loaded''
I fixed the issue by restoring windows to a previous date, I had installed a new version of java the previous day so luckily nothing was lost when I restored it. This issue happened again, fixed it with the restoring again. After that it hasn't happened again. Now I'm wondering, why did it happen and what can I do to prevent it from happening again? If it happens again and I dont have a backup that windows made recently I could potentially loose alot of work.
I've also had the issue with lag when gaming. I play games like Team fortress 2, need for speed and minecraft.
I used to play TF2 on 720p because I lagged alot, frames dropped to as low as 10 FPS really often. Then I turned off multithreaded rendering.
Suddenly I never ever got lag spikes. Now I can play at 1080p without any issues at all. Could it have been because of my CPU throttling when I had multithreaded on? I know my CPU get's easely to 90ish degrees now when gaming. I do have a cooling pad.
Laptops sucks -.-
