What up TS. I'm trying to look for a replacement LCD for a Asus F6A - (LCD is B133EW01 V.3) and some of these prices are outrageous. So I'm looking for a compatible LCD for under $110 (if really possible) within the states. Some of the sites I see write "all you need to match is":
30 or 40-pin (30-Pin)
Screen Type (CCFL Single Bulb Lamp- NOT LED)
Size (13.3 WideScreen 11.3"x7.1")
Resolution (WXGA 1280x800)
I found a spec sheet at PDF-Here. Any help or information would be greatly appreciated.
Keep in mind, I have not seen the laptop itself yet. My brother gave me a call and gave me model numbers etc, but I will have a look at it myself later on and get more info if need be. Also if anyone knows really great/reputable sellers, some info/links will also be appreciated.
Nerd Rage
(P.S. At the time of post, sites showing low prices are out of stock... go figure...)
