=Laptop help=
Hey everyone I know this is probably the wrong section to put this post in (I had no idea where to so sorry :/), but I have a little problem in my hands right now and could use a little help.
My girlfriend is going into Uni in september and she's going to get a new laptop, but instead of letting her just get a random one I'd thought I'd search for one that would be the best bang for her buck and would fit her best.
From what she told me her budget is around 600£ and she's going to use it mostly to browse the internet, listen to music and maybe play The Sims 3 and 4.
Can you guys leave me some recommendations?
Thanks and have a great day!
Luís
Yes I can but I have to leave for work at the moment. Once I get there and get settled in I will see what i can find for you give me  like 2.5 - 3 hrs and i will post something for you if some one else doesn't beet me to it
This Intel base looks pretty solid and meets your price point...
MSI GP60 Leopard-009 Gaming Laptop Intel Core i7 4700HQ (2.40GHz) 8GB Memory 750GB HDD NVIDIA GeForce GT 840M 2GB 15.6" Windows 8.1 Multi-language
http://www.newegg.com/Product/Product.aspx?Item=N82E16834152569
or here is an AMD that kills for just a few extra $
MSI GX Series GX60 Destroyer-280 Gaming Laptop AMD A-Series A10-5750M (2.50GHz) 8GB Memory 1TB HDD AMD Radeon R9 M290X 2GB 15.6" Windows 8.1 64-Bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16834152563
Please note that these are just my opinions and not necessarily recommendations.
With that said ... if I were to throw a $1000 dollars at a laptop ... it would probably be close to these.
here is a nice laptop from Currys
it is £699.00  but has a £100.00 rebate making it £599.00
Intel® Core™ i7-4510U Processor
8 GB RAM
1tb HDD
it also has a NVIDIA GeForce 840M
This should run the sims 4 based on anticipated system requirements for the game. It will absolutely run Sims 3
This laptop should take her all the way trough the end of uni (unless she starts to study something crazy)
http://www.currys.co.uk/gbuk/computing/laptops/laptops/lenovo-z50-70-15-6-laptop-white-10022810-pdt.html
Thanks a lot man!
I'm checking this one with her right now and wow thanks! This was just what we were looking for!
Cheers
No problem! Enjoy your new laptop.
