Hey all,
I am looking for a laptop to do some work with office applications and web browsing. It shouldn't be a Chromebook because I want to actually store documents and have it be usable offline but I also don't need a dedicated GPU. A touchscreen is also not necessary. Do you know of a product you can recommend?
That's the thing, I don't know. It's not for me personally. I'd say up to 500$.
Well I have one called the Asus x200ca http://www.asus.com/Notebooks_Ultrabooks/X200CA/
It has an i3 CPU 4GB RAM and a 500GB HDD. It's also 11.6" so it's really portable, the only bad part is the battery life, only lasts a couple of hours, but the charger is quite small so it's easy to move around :)
