As you can see from the title, my laptop's fans do not start to spin whatsoever. I have not touched any software to change fan curves or anything of the sort. As you can tell it would get really hot, any suggestions?
is there on any of the f keys a blue fan icon? if so, it might be that you need to press the fn key and press that f key at the same time. if ot, are they jammed by something? sorry if you feel like im insulting your intellegence or anything, but people do just forget about the simple things sometimes :)
hope this helps,
tom
Check the stuff that Tom said but you have have to open up access panels or tear down your laptop to see if they've become jammed or they just died. How old is your laptop?
