Lap desks sugesstions?
hey I just bought a 2017 MacBook pro, and sometimes I have to work at night, things get rough sometimes so I have to take rest and work simultaneously, so I thought might as well get a Lap desk so that I can work while I’m in bed. What are the best lap desks out there under $50? Thanks in advance.
Honestly most are over priced plastic and/or wood making one will do wonders or have a medical bed table keeps the cushion or table off the legs and not weird
Honestly, there are tons of options out there but for your situation I’d suggest going with a memory foam lap desk as other options have metal stands which can get annoying, you can find some of the best memory foam lap desks here https://appuals.com/best-lap-desks if you’re looking to break down the best of them between each other. cheers
