LAGG Pfsense Issues
So Santa delivered a ZyXEL GS1900-24E, witch seems great on paper however, upon reboot it loses all of its configuration information so its being returned… I will be getting something a little better to setup the Lag, will post on here when that happens. probable be a few weeks.
Are you sure it didn’t have a save option or something like that? Some of the switches I’ve used won’t keep the settings between reboots unless you manually save it (not just apply the changes) so that if you mess something up you can just reboot and go back to the old config.
I did check on that and no as of the latest firmware it did not have that option. I send it back and purchased Cisco SG200-26 (SLM2024T-NA) , it should be arriving tomorrow hopefully then I can setup my lag connection between my servers so excited!
