Hello there,
I just bought a 3 monitor 2 PC (5 Gbit/s) KVM and having some issues with it.
My setup:
PC1: Windows
RTX 3090
3 DP to DP 1.4 Cables to the KVM
PC2: MacBook Pro 16’’ (2019)
3 USB-C to DP Cables connected to KVM
Monitors:
A: 1 21:9 2k 165Hz Monitor with FreeSync connected via DP to DP
B: 1 16:9 2k 144Hz Monitor with GSync connected via DP to DP
C: 1 16:9 FullHD 75Hz Monitor connected via DP to HDMI
Only Monitor A is working with both PCs.
Monitor B isn’t working with any PC. After powering the KVM off and turning it on again it now works for both PC. But I did that before already multiples times where it didn’t work.
Monitor C is working only with PC1.
I have tried switching cables and ports on the KVM with the same result for any combination.
All 3 USB-C to DP cables are working for Monitor A, but not for the other Monitors.
I also have the issue that sometimes when switched to PC1 my keyboard input is passed to PC2, every other USB device connected to the KVM is connected to PC1 only the keyboard isn’t.
Could the issue with Monitor C be related to cables even though they are all working for Monitor A?
Is the issue with Monitor B related to it having GSync and if so is there a way to get it working?
Kind regards,
Dracsos
