Backpressure can do it, happens in high horsepower applications cylinder 3 likes to crack ringlands with wrx/sti unless if you convert to equal length headers which sounds like garbage in a Subaru.
Essentially the epitome of first world problems.
It’s basically a fucking meme, I’d be more likely to snap the crankshaft or crack the block since its open deck.
I thought I did: Essentially your are using the exhaust pulses to extract more exhaust from the cylinder. The timing is critical as the pulses travel at a linear speed. So most headers don’t make more horsepower but shift the powerband up the rpm scale.
Okay, so, with that in mind, what happens when the header is of unequal length (with subarus in particular) is that the drivers side has to fight to get out and the passenger side flows more easily. This causes uneven conditions of multiple things but mainly heat. When this gets further exaggerated in high horsepower applications shit can go sideways. unequal distribution of heat through the engine can cause some cylinders to predetonate due to varying conditions which mainly leads to ringland failure above any other points of failure.
This can be circumvented with stronger internals but i’ve got stock internals so things like this are a real concern.
Thanks. That makes sense. I was under the assumption that with a turbo that equal length didn’t matter. Perhaps it doesn’t matter in a stock situation.
Only thing I want to do now is the class 3 tow hitch and 7 pin harness.
Not sure about a full bed liner though since I can just throw in a nice 3/8 inch thick rubber mat into the bed for about $100.
Every truck I own that had a bedliner in it has a rusted box. If I wanted to protect the bed I would use something easily removable for cleaning. Fluid Film on the underside every fall.
Yep agreed bed liner locks moisture in and rots from the inside out. There is no correct way to apply it after a truck has left the factory. My bed looks like Swiss cheese Previous owner taped over the holes with duct tape then sprayed over it again.
found a 1996 Nissan hardbody D21 2wd 5 speed for sale locally with 42k miles on the side of the road some old mans truck… literally dream truck but i already have a car and a truck, texted my buddy who also likes d21s to check it out he’s taking it for a test drive tomorrow.
