Status update: Miata is back up on stands, gonna bleed the brakes today or tomorrow, whenever I have time. Once that’s done, I’m taking it out for a couple drives to make sure it’s not a death trap, then I’m switching back to the megasquirt to chase down that electrical problem. Then turbo.
So, list:
fix brake hydraulics
plug megasquirt back in
wire Wideband to signal ground on MS
wire AC switch through megasquirt so I can handle idle-up in software
buy turbo
Possibly wire in switch to enable/disable flatfoot shifting and two-step.
The 2012-2013 Subaru Imprezas are known for consuming excessive amounts of oil. After a class action lawsuit (of like 8 people) Subaru agreed to extend the warranty on certain model years of Subarus to cover the oil consumption. My car went through an entire quart in 3000 miles. The recommended oil change interval is 7500 miles, so my car would consume about 2.5 quarts of oil, or just under half of its capacity, within the recommended oil change interval.
You do not want to pay for the fix out of pocket because the fix involves replacing the entire shortblock, which is over $2000 by itself. Add in gaskets, bolts, washers, ~12 hours of labor, and whatnot and it would get very expensive very quick.
I agree it will sell better, but the fact of the matter is that they’re going to be hard pressed to beat the value of the 2019 mx5. If they do, it’s gonna have my dollar though.
This is still just a concept, right? I hope they soften it up a bit before finality. The problem I see with it is that they’re cannibalizing their own market. This would be something for the person who wants a 2-seat m3, not someone who would otherwise buy a Miata. Also, if they don’t offer a 6 speed manual, they’re going to regret it.
Maybe I’m biased. When I was in the market for a e36 m3, I skipped on that in lieu of my Miata and that turned out to be the best decision I’ve made in a while.
What’s the target market then? I always thought roadsters were for people who enjoyed driving. I get that dual-clutch autos can be fun, but I’d much rather have a manually operated clutch for my weekend car.
Agreed. They’re going to need to change the headlights, taillights and change up the plate mounts, from what I can see. This won’t sell in the US as is.
I don’t know why they want two turbos as opposed to one with less rotational mass. It’s not like they’re making 3bar or so on that engine, which would justify one small and one larger.
Complexity for dick measuring is not cool.
But one way or another 340hp isn’t bad at all. That’s pretty much m3 performance range if the weight is gonna be similar.
