Posting here as I emailed Wendell but I don’t think that’s a very scalable solution.
I am planning to get a Level1 KVM.
Before I plonk down $1000+AUD, I’d like to work out if the following will work:
2x laptops connected via HDMI
1x PC connected via USB C to DisplayPort or via HDMI
1x gaming PC connected via DisplayPort (needs VRR/144hz)
Currently I use a janky USB switcher and my monitor’s USB hub.
I would like to keep using my monitor’s hub.
I would like to use HDMI for the laptops due to ease of cabling and only needing 1440p/4K/60.
I’m currently using an Acer Predator 144hz 1440p monitor, I’m likely to upgrade to a Gigabyte 1440p or 4k monitor in the future.
This would be connected via DisplayPort.
(I’d probably buy the two output version for future expansion)
Am I going to be causing problems by trying to convert “back” to HDMI?
I plonked down roughly that amount for the 4 PC 2 Monitor KVM and initially had one 1440p DP monitor and one 1080p HDMI monitor which never seemed to work reliably converting back from DP on the KVM side to HDMI on the monitor. Maybe something like this (DP Repeater + HDMI Splitter — Level 1 Techs) will allow that to work as the options I tried were cheap from Amazon AU. In the end I got another 1080p monitor with DP.
If you are going to 4K in the future and want 120Hz+ with HDR, keep in mind this can be finicky through the KVM. Even with the FIBBR cables that are recommended. I upgraded to a Neo G8 and a 4K60 for my secondary. The combination of my Neo G8 and 3080Ti I was never able to get it working. Switching in a 6900XT and it seems to work fine. Cables really do matter.
Well said! Cables really do matter. Also, converting to HDMI is pretty annoying. As long as he has a powered “active” adapter for the HDMI it will probably be fine for your 1440p setup. I also had someone on the forum report they had an active all-in-one cable. I would stick to the adapter, though.
Converting to HDMI will probably lower you to DP 1.2 meaning 4K/120Hz isn’t going to work. As he said, sometimes it’s a struggle getting 4K/120hz hdr on (for big KVMs) just normally, no converting.
