I’ve been using my DP1.4 dual monitor KVM without any video or USB issues, but decided to finally also hook up my audio and noticed that I’m getting consistent buzzing when plugged into the KVM. When no audio is coming from either input I get an audible buzz from my speakers/headphones. I’ve tried switching audio cables, running those audio cables in the same locations (to rule out any feedback from nearby wires) and the only way to get the buzz is to plug my speakers or headphones into the KVM. Anyone else experienced this, or figured a way around it?
Irs most likely a ground loop. Pick up a ground loop isolator and that should fix you up
