L1 Store: KVM Restocking
@Level1_Amber Is there a restock update on the " HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer". Thank you so much!
We have some on order, but they have not shipped from our OEM yet unfortunately. They are anticipated closer to August
I am in interested in the single monitor HDMI 2.1, Quad Input. How do I get on the notify list?
I found my way here by google searches looking for the ultimate stable HDMI KVM. It’s nothing but issues out there from the $50-$250 KVMs I’ve tried. Either USB ports don’t move over when switching inputs, the screen goes black for 1-2 seconds, or the most recent is the screen artifacts and flicker for split second.
What makes these L1 KVMs better and more stable?
We have a product that isn’t cheaply made, the KVM’s hardware and firmware are constantly trying to be improved when situations do occur. The L1 KVMs came about as a passion product because there were no great options on the market.
As Wendell says, there is no perfect KVM because of how complex and universal they have to be, but ours are pretty darn good.
This sounds like you need better cables
What HDMI cables do you recommend? I bought what I thought were very nice quality ‘Zeskit’ branded cables which are top of the HDMI cable charts for Amazon purchases.
Also, how do I get notification when the KVM comes back in stock?
Sorry I meant to reply to this. You can sign up via email
How long are they? Do you have a link?
I am not allowed to put links in these comments. If you go to Amazon and search for this:
Zeskit Certified 2.1 8K HDMI Cable 48Gbps 4K120Hz Compatible with Soundbar eARC HDR10 VRR Dolby Vision Atmos HDCP 2.2 & 2.3 Gaming PS5 Xbox Series X Apple TV Roku Monitor (Ultra High Speed, Maya 5ft)
Zeskit Maya 8K 48Gbps Certified Ultra High Speed HDMI Cable 3ft, 4K120 8K60 144Hz eARC HDR HDCP 2.2 2.3 Compatible with Dolby Vision Apple TV 4K Roku Sony LG Samsung Xbox Series X RTX 3080 PS4 PS5
I am using a 5ft cable between PC and KVM, and a 3ft cable between OLED and KVM.
Hm, these would seem like they’re probably fine, you might try 1 leg of the connection as fiber optic?
Will there be a restock of the USB-C Combiner any time soon?
We have them noted as need to order, but have not placed the order with our OEM. So, it’ll be a bit.
Will there be any restock on the 10gig displayport quad monitor to 2 PC kvms?
Or is it more likely that displayport 2.1 versions will be out first?
I’m interested in getting EDID KVMs, one single-monitor and one dual-monitor. Does L1 make DisplayPort variants with EDID, or just HDMI? And if there are DP ones, will they be available any time soon?
I’d be happy with the HDMI ones as well, just want to know what my options might realistically be before purchasing / buying more cables.
We have a DP 1.2 dual monitor dual PC KVM here:
but that is all
DP 2.1 will not be out before a restock of those. They are on order though
Got it, thanks!
Last q - what about dual PC single monitor KVMs? (So, the same as the EDID HDMI ones that’re in stock, just for 2 computers instead of 4)
You’re wanting to know if dual hdmi 2.1 KVMs are coming somtime?
Correct - single monitor, dual PC w/ edid (hdmi and dp both fine)
We have some new, open box, used, and more at our local office! If you are interested, DM me and I’ll give you more specific options.
