I have the usb-c 1.4 Display Port KVM Switch (Single Monitor - Two Computer) which I am trying to use with a desktop PC and a Macbook Air (M1). I have an ultrawide monitor, a keyboard, a mouse, a webcam and a DAC plugged into the KVM.
How I use it
For the Macbook (since it only has two thunderbolt ports), I have the USB-C cable plugged directly into the laptop, and the DP 1.4 cable ( Club3D VESA Certified CAC-2068 DisplayPort to DisplayPort 1.4/Hbr3 Cable DP 1.4 8K 60Hz 2M) is plugged into a Cable Matters multiport adapter (Cable Matters USB C Multiport Adapter (USB C Hub with DisplayPort 8K), 2X USB 2.0, 480 Mbps Ethernet, and 100W Charging) along with the power cable for the Macbook.
The problem
On the Macbook Air, any black colour on the monitor “sparkles” with white pixels, and the screen will periodically go black. The KVM works perfectly on the PC.
Any ideas on what could be wrong and what I could do?
Sorry, what do you mean by that? I’m totally new to Apple products - this Airbook is the first Apple product I’ve used and I’ve only had it a week
Apple devices may not be compatible with PC devices by design. As in Apple breaks compatibility because they only want you to use Apple and Apple approved devices.
Please see above my current test cases. Will order some shorter DP1.4 cables (maybe two 1m cables so total run from monitor > kvm > laptop is 2m).
I’m also experiencing some weird mouse acceleration antics (not wireless - it’s usb plugged into the KVM; specifically a Logitech G403), any ideas on how/whether I can fix that? Basically when moving my mouse across the screen the speed seems to be inconsistent (as in it occurs inconsistently, and when it occurs the speed itself is inconsistent).
kay, so, this adapter is one of the unfortuante ones that “senses” a monitor is plugged into it by using the ground pins or something. So when you do anything with the kvm, it doesn’t think a monitor is plugged in. These arent dumb adapters. You probably should try the moshi, or another brand, since it is bidirectional.
The accelration thing I’m looking into. You can use it on the usb3 side of the kvm and the kvm will leave it alone. The mouse sometimes seems to be sending an 8 byte mouse packet when its in 20 byte mode, so not sure why that is causing that.
I can’t use the Moshi cable unfortunately because it doesn’t also provide power delivery. The Macbook Air M1 only has two thunderbolt ports, so if I plug in the USB-C from the KVM and then a DisplayPort-thunderbolt cable, there are no ports left for the charger. So I need to combine the charger and DisplayPort cables - hence this adapter.
Hmm that’s no good. Does the brick thing with Ethernet not have usb passthrough? Usually when they do multiple functions and charging they also have a passthrough usb port or two
I would put the DP cable from the kvm straight into that, and then a USB-C → USB-A cable from the KVM into that, plug the adapter into one thunderbolt port on the MacBook and the charger into the other.
