Kworker hangs my pc
Hello guys, this kworker process is so annoying, it uses the cpu alot and make the whole system hang.
I tried to stop it but I don’t have good knowledge of processes management.
and I didn’t find alot of resources online, and the ones I found talks about config files that just isn’t there.
I use fedora 29, I think I did upgrade from 28.
thanks a lot for the help.
kworker is the kernel worker thread placeholder in system statistics.
System specs, kernel version, DE, what you’re doing when it starts hanging?
Nothing special, Firefox and thunder.
Sometimes Firefox not opened, sometimes just updating my system.
so what do you think
This solution is for Ubuntu, but might work for you:
https://pushingkarma.com/n/ubuntu-fix-kworker-high-cpu-usage/
I think that I need more system information before I can tell you what’s going on.
What information do you need to know??
I can provide you with them
System specs. CPU, Chipset, RAM, GPU, GPU drivers used, what protocol your HDD/SSD is using.
Also, the output from lsmod would be helpful.
I use intel i3 8100 on asus rog strix b360-f gaming mother board with gtx 1050 2G from “galax”.
I didn’t install any drivers for the graphics card I use what comes with fedora, no rpm fusion repo is added.
It’s sata3 ssd and a partition of an hdd mounted to /home/my user/folder and that partition is encrypted
I didn’t find any high value, all was 0 :frowning:️
Module Size Used by
fuse 122880 3
xt_CHECKSUM 16384 1
ipt_MASQUERADE 16384 3
tun 45056 1
bridge 188416 0
stp 16384 1 bridge
llc 16384 2 bridge,stp
devlink 77824 0
nf_conntrack_netbios_ns 16384 1
nf_conntrack_broadcast 16384 1 nf_conntrack_netbios_ns
xt_CT 16384 1
ip6t_rpfilter 16384 1
ip6t_REJECT 16384 2
nf_reject_ipv6 16384 1 ip6t_REJECT
xt_conntrack 16384 22
ebtable_nat 16384 1
ip6table_nat 16384 1
nf_nat_ipv6 16384 1 ip6table_nat
ip6table_mangle 16384 1
ip6table_raw 16384 1
ip6table_security 16384 1
iptable_nat 16384 1
nf_nat_ipv4 16384 2 ipt_MASQUERADE,iptable_nat
nf_nat 36864 2 nf_nat_ipv6,nf_nat_ipv4
iptable_mangle 16384 1
iptable_raw 16384 1
iptable_security 16384 1
nf_conntrack 163840 8 xt_conntrack,nf_nat,nf_nat_ipv6,ipt_MASQUERADE,nf_conntrack_netbios_ns,nf_nat_ipv4,nf_conntrack_broadcast,xt_CT
nf_defrag_ipv6 20480 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
libcrc32c 16384 2 nf_conntrack,nf_nat
ip_set 45056 0
nfnetlink 16384 1 ip_set
ebtable_filter 16384 1
ebtables 36864 2 ebtable_nat,ebtable_filter
ip6table_filter 16384 1
ip6_tables 32768 7 ip6table_filter,ip6table_raw,ip6table_nat,ip6table_mangle,ip6table_security
dm_crypt 40960 1
sunrpc 425984 1
vfat 20480 1
fat 81920 1 vfat
intel_rapl 24576 0
x86_pkg_temp_thermal 16384 0
intel_powerclamp 16384 0
coretemp 16384 0
kvm_intel 241664 0
snd_hda_codec_hdmi 57344 1
kvm 737280 1 kvm_intel
iTCO_wdt 16384 0
iTCO_vendor_support 16384 1 iTCO_wdt
irqbypass 16384 1 kvm
crct10dif_pclmul 16384 0
crc32_pclmul 16384 0
ghash_clmulni_intel 16384 0
intel_cstate 16384 0
intel_uncore 135168 0
intel_rapl_perf 16384 0
snd_hda_codec_realtek 110592 1
snd_hda_codec_generic 86016 1 snd_hda_codec_realtek
snd_hda_intel 45056 7
snd_hda_codec 151552 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
eeepc_wmi 16384 0
asus_wmi 32768 1 eeepc_wmi
sparse_keymap 16384 1 asus_wmi
snd_hda_core 94208 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
rfkill 28672 4 asus_wmi
snd_hwdep 16384 1 snd_hda_codec
snd_seq 81920 0
wmi_bmof 16384 0
snd_seq_device 16384 1 snd_seq
snd_pcm 114688 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
joydev 24576 0
snd_timer 36864 2 snd_seq,snd_pcm
snd 90112 24 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
mei_me 45056 0
soundcore 16384 1 snd
mei 118784 1 mei_me
i2c_i801 28672 0
acpi_pad 36864 0
pcc_cpufreq 16384 0
nouveau 2187264 11
mxm_wmi 16384 1 nouveau
i2c_algo_bit 16384 1 nouveau
drm_kms_helper 196608 1 nouveau
ttm 131072 1 nouveau
drm 487424 14 drm_kms_helper,ttm,nouveau
e1000e 282624 0
crc32c_intel 24576 6
wmi 28672 4 asus_wmi,wmi_bmof,mxm_wmi,nouveau
video 45056 2 asus_wmi,nouveau
This is the lsmod output
Help me pleae it’s becoming disgusting to use it
I’ve just reinstalled a fresh system again and I had the same issue.
I gave my self the root privileges editing /etc/sudera, updated the system then rebooted it, installed thunderbird, removed evolution, installed nano, KDE connect, breeze-cursor-theme, numix gtk and numix circle.
then I luanched thunderbird, and boom, lags lags and lags.
It’s becoming a disaster :frowning:️
Was there any problem prior to thunderbird being installed?
Try removing thunderbird from your system to see if that’s the problem. I’ve seen thunderbird cause major problems before.
Nope, wasn’t, it was the 1050 GPU.
I installed the proprietary driver from rpm fusion and it worked great.
I think I’ll get me an AMD graphics card
Glad to hear!
That was going to be my next recommendation, but I didn’t want to make too many suggestions.
