KVM Woes
@wendell
I recently purchased a KVM 2 monitor 2 computer 5 gig from LevelOne and I’m having some issues. The two computers I am using it with is a Ryzen build and a Dell work laptop. I am using two LG 1440p monitors.
Ryzen build issue: The main issue I am having with it is the keyboard and mouse cutting in and out. I have a Model M and the keyboard will just quit working and I will have to unplug and plug the adapter in a few times. Then it quits acting up and works normal again. The mouse quit moving at random times and pick back up. There is no pattern to the mouse and sometimes it will just drop for 1 second then resume. Both monitor work with no issues. I have tried swapping to PCs on the KVM to see if there is something wrong with a specific port with no luck. I have also tried multiple USB3.0 cables and ports on the motherboard.
Laptop issue: I’m using a dock (Dell TB16) with the laptop and having no luck getting either monitor to fully display (this dock doesn’t have issues driving these monitors without the KVM). I don’t seem to be having the same mouse and keyboard cut out like the my Ryzen build so that also adds confusion. I haven’t been able to bypass the dock completely and hook directly to the laptop due to my the lack of HDMI to DP and mini DP to DP adapters. I have swapped cables around and used the desktop cables to the laptop and have had no luck. Sometimes the laptop can detect one of the monitor and display a black screen but it does not really create a full image.
What next:
I’m not sure if there something I need to do in my setup between cables or some other change. I am looking for any advice on what I can do to get this to work. Or could I possibly have a bad unit? Before this I was using an ancient Cables2Go VGA KVM before and I was not having any issues.
What adapter are you using with it, and have you tried a usb3 port? those are straight passthrough and dont mess with the signal at all. A different PS2 to USB adapter would probably work. I designed a QMK based internal model M adapter for this eventuality.
Ryzen has a number of media/usb controllers. The port you have selected may be an unfortunate asmedia port. Try a different usb port group and it’ll probably clear up.
TB16 from Dell has A Lot Of Firmware Updates. Are you fully up to date there? That matters a fair bit. It could be causing the desktop pc to struggle since the hid ports are kind of “shared” between hosts.
I’m using a Monoprice adapter and I haven’t had any issues ins the past… (Monoprice USB to PS/2 Dual PS2 Converter Adapter - Monoprice.com). I’ll try a different set of USB ports on Ryzen.
I didn’t even think about the TB16 firmware. I’ll give that a try and see what happens.
try the usb3 port since that’s straight passthrough. The ps2 adapter might be hid 1.0 so its worth trying the other usb ports on your desktop machine also
