**KVM Model:** 4-Port HDMI KVM (Single Monitor) not working
KVM Model: 4-Port HDMI KVM (Single Monitor)
USB Interface: [5-gigabit or 10-gigabit — please fill in]
Problem:
I’m not getting any display output on my monitor despite USB passthrough working correctly on both active ports.
Setup:
  • Port 1: Alienware X16 → Dell SD25TBS Thunderbolt Dock → KVM
  • Port 2: Dell Latitude → WD19TB Thunderbolt Dock → KVM
  • Monitor Output: KVM → Samsung 49" 32:9 Ultrawide (via HDMI)
Symptoms:
  • Front panel LEDs show solid green on both ports 1 & 2, switching to green/red when a port is selected — so the KVM is detecting both computers
  • USB passthrough works correctly on both ports with no issues
  • No display signal on either port — monitor shows “No Signal”
  • The rear LED next to the HDCP switch shows green when port 1 is selected and blue when port 2 is selected
  • Occasionally when switching inputs, the display will briefly appear and then go blank again when I switch away and back
  • Connecting the monitor directly to either laptop produces a signal with no issues
What I’ve already tried:
  • Full disconnect of all cables for 5+ minutes, then reconnect
  • Held the EDID button until the KVM restarted
  • Cycled through all HDCP options on the rear switch
  • Changed the monitor’s HDMI input mode between HDMI 1.4 and HDMI 2.0
  • Tried different HDMI ports on the monitor
History:
This unit was previously working. Most recently it was running with just the Latitude + WD19TB and was working fine. The issue started today after I reconnected everything with the Alienware added to the setup.
The fact that it occasionally flashes a working image when switching suggests the signal path is capable of working but something in the EDID/HDCP handshake is failing to hold.
Any ideas would be greatly appreciated — thanks in advance!
