KVM Model:
HDMI 2.1 KVM w/EDID & Serial Control - Single Monitor - Four Computer
type here
Problem:
I’ve had the KVM hooked up for about 14 months now, and it’s been pretty smooth sailing, no complaints - until yesterday.
The Mac Mini M2 is my daily driver (KVM Port 1), while the other two are SSH-only and I only hooked them up to the KVM only to let me install OSes and debug any SSH issues (very rarely used). Those two computers have been off for a couple of months now (still plugged in to the KVM, though).
The problem I’m having cropped up yesterday and I just had the second instance of it an hour ago. The symptoms are as follows:
- After the Mac/monitor go to sleep, I press my keyboard, my Apple Watch vibrates to notify my that my computer is unlocked
- My monitor LED goes white indicating it thinks it should turn on
- After 20-30ish seconds, the LED goes yellow with a No Signal and then Low Power
- I’m unable to get my Mac to show up on the monitor without a KVM power cycle
- Yesterday morning, the monitor had been in low-power mode overnight before this problem, today it had been in low-power for about 15-20 minutes and I came back to this problem
- My Mac is set to turn off the display if inactive for 10 minutes, and locks immediately
What I’ve tried yesterday and today while it was in this non-operational state (before power cycling the KVM):
- Using the alternate HDMI port on my monitor (monitor white LED goes on, then no signal, then sleep again)
- Hooking up another computer directly to my monitor to ensure the monitor was working (it was)
- Plugging in the Mac to another monitor to verify it was, in fact, on and outputting its display (yes, it was, and it was already logged in and outputting display)
- Manually changing the KVM’s display output and going back (monitor white LED goes on, then no signal, then sleep again)
- Unplugging and re-plugging the HDMI cable to the same KVM Port 1 (monitor white LED goes on, then no signal, then sleep again)
- Moving the HDMI from Port 1 to Port 2 on the KVM and selecting it as the display output (monitor white LED goes on, then no signal, then sleep again)
After all this failed, I didn’t have any other ideas - so I tried a power cycle, and I was up and running in like 20 seconds (correctly logged in to my Mac already, meaning my Mac was awake and outputting display).
I don’t know if this is relevant, but with the HDMI unplugged, the green LED on the KVM port was still on. I’m guessing this is the case when the USB is plugged in. When I removed the power plug from the KVM, Port 3 was still illuminated green. I’m pretty sure it’s always been like that.
So, after all that, I don’t know what to do/try next. It feels like something is going sideways here. My Mac is correctly responding to my keyboard to wake it up, which is also through the KVM, but the output display wasn’t working.
As far as my troubleshooting shows, everything else in the system appears to be working correctly independently.
Other Notes:
Monitor: Asus VG34VQL3A (few months old)
HDMI 1: Mac Mini M2 Pro (OS 26.3.1 - 3440x1440 - 100Hz)
HDMI 2: Headless custom Intel PC running Alpine (Powered, but off)
HDMI 3: Headless Mac Mini x86 running Fedora (Powered, but off)
Logitech G305 and Ergo K860 wirelessly transmitting to KVM via UGreen 7-port USB3 hub
Cables: Infinite Cables Ultra High-Speed HDMI 2.1 Certified 8K@60Hz 48Gbps UHD HDR Cable (all of them, mostly 3 ft runs, the run to the monitor is 10 ft)
Everything powered via a UPS - have not experienced any power-related issues on any of my hardware.
